  • durga ch
    @durga-TpX3gO Feb 11, 2012
    ... do you mean you need the server to push a script to poweroff the clients??
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 Feb 11, 2012
    Hey, you can do this is two ways:
    Command Mode
    Open Start » Run, type cmd and press enter.
    Type shutdown -m \\computername, where computername is the hostname of the computer, connected in the LAN.
    GUI Mode
    In the Run, type shutdown -i and press enter.
    Click the "Add" box and type the name of the computer you want to shutdown or it's IP address. You can select what you want the computer to do.
    In this mode, it is NECESSARY to add a comment. Finally press "OK".
    Hope this helps! 😀
  • sunilrk
    @sunilrk-ZCaHW6 Feb 16, 2012
    Yes the server should push the script to shutdown the clients
