Sanitary Pipe Broken: Replacement Help
I'm new to this section. A problem made me enter to this section of crazy engineers.
The problem is that a sanitary pipe that was connected to our building was broken by a crane, that was on a work. It was intentional, they wanted to plug in a huge water pipe, so they had to make a path for that pipe. So, they broke sanitary pipe that was connected to our building.
Please tell me the steps/cares that need to be taken while repairing it. The material of the pipe is hard stone/RCCcement like material, should i be okay with using PVC pipes? And should i replace the complete pipe/ only the part broken? Is it okay, if there is a slight increase in its hight(about 1 ft), wouldnt it block the sewage,(does the increase in height create prob, because the huge pipe below is obstructing the path of sanitary pipe?
Image indicates the problem.
