[Safeguard] Best way for product to only work when in water?
Hi guys,
I'm developing a product that will be submerged only 1-2 feet under water while 1/3 feet of the upper body will be above the surface. The tech is not intended to be used when not in water as it generates some heat and may gradually destroy it's main components if used dry over time.
What I'm looking for is a good and cheap method to safeguard this for our customers. Considering the product is waterproofed, how to correctly sensor water location by a few inches? The product can only be started by app through BT or WiFi. So the goal is to not be able to turn it on in the app if the product's sensors detects no water around or on its body. Also it's preferred, but not necessary, that it auto stops the process if pulled out of the water.
Will those cheap ultrasonic sensors work if connected to the programmable chip? Or are there any better, more safe methods that you would recommend me looking into?
Thanks in advance for any help!
- Ed
