running php script using xampp
jatin-phoenix
@jatin-phoenix-qCwzlm โ€ข Oct 26, 2024
i installed xampp version 1.7.0.
after that i created a script test.php inside
htdocs folder.
i tried running it using
it does not run and the error it gives is
object not found and error 404.
what do i do? somebody help!
    @thebigk • Jun 9, 2009
    The path would be #-Link-Snipped-#
    Make sure you have apache running.
    If that too doesn't work, first make sure you get XAMPP screen at #-Link-Snipped-#
    If that fails, try #-Link-Snipped-#
    Let us know what results you get.
  • jatin-phoenix
    @jatin-phoenix-qCwzlm • Jun 9, 2009
    i did what u told . this is the screen i am getting. i checked from apache panel. apache is running.
    Object not found!
    The requested URL was not found on this server. If you entered the URL manually please check your spelling and try again.
    If you think this is a server error, please contact the webmaster.
    Error 404
    localhost
    06/10/09 16:13:53
    Apache/2.2.11 (Win32) DAV/2 mod_ssl/2.2.11 OpenSSL/0.9.8i mod_autoindex_color PHP/5.2.8
    @thebigk • Jun 10, 2009
    Okay, follow these steps and let me know at what stage things go wrong -
    1. Start XAMPP control panel.
    2. Start Apache
    3. Fire up Mozilla or IE.
    4. Type #-Link-Snipped-# -> Should give you XAMPP page.
    5. If #4 dosen't work, try #-Link-Snipped-# -> Should give you XAMPP page.
    6. Go to #-Link-Snipped-# -> If the code is right, should produce results.
    Now, post following information -
    1. Your OS.
    2. Complete path to "htdocs" folder.
    Assumption: You've made a default-options install and haven't configured apache manually.
  • jatin-phoenix
    @jatin-phoenix-qCwzlm • Jun 10, 2009
    it works now biggie.
    thanks a lot for the help.
    @thebigk • Jun 11, 2009
    jatin-phoenixit works now biggie.
    Alright . Good to hear that! [โ€‹IMG]
  • jhbalaji
    @jhbalaji-AH60JJ • Jul 25, 2009
    You must first start it then goto localhost mate...
