  • Rotor without stator?
    pknaveen17
    Member
    Updated: Oct 26, 2024
    Views: 1.0K
    If a rotor without stator having 3 phase AC winding and free to rotate, if 3 phase power supply is given to its winding through slip ring, then what happen, rotor will rotate or not, if yes please explain?
  • zaveri
    MemberApr 26, 2012
    a 3 phase supply produces a rotating magnetic field, but yet i think it would be useless without a stator.
    basically a.c motors or induction motors are also called as rotating transformers, which means that the rotor and stator cannot function independently.
    the use of a 3-phase winding only eliminates the use of a capacitor, which is used with single phase induction motor, to help it to start, since the same aren't self starting,
    and in the case of 3-phase motors, the winding is present on the stator, and the magnetic field that is produced by the energizing of the windings forces the rotor in to action.
    so hence the idea of a rotor working without a stator or vice versa sounds absurd
  • lalit.joshi
    MemberApr 27, 2012
    pknaveen17
    m totally agree with zaveri,
  • aarthivg
    MemberMay 3, 2012
    I have a doubt
    In an AC motor, the winding will be in stator or rotor
  • Mr.Don
    MemberMay 3, 2012
    Winding is present in Both Stator and Rotor.
  • aarthivg
    MemberMay 3, 2012
    An AC motor is an <a href="https://en.wikipedia.org/wiki/Electric_motor" target="_blank" rel="nofollow noopener noreferrer">Electric Motor</a> driven by an <a href="https://en.wikipedia.org/wiki/Alternating_current" target="_blank" rel="nofollow noopener noreferrer">Alternating current - Wikipedia</a>.
    It commonly consists of two basic parts, an outside stationary <a href="https://en.wikipedia.org/wiki/Stator" target="_blank" rel="nofollow noopener noreferrer">Stator</a> having coils supplied with alternating current to produce a rotating magnetic field, and an inside <a href="https://en.wikipedia.org/wiki/Rotor_%28electric%29" target="_blank" rel="nofollow noopener noreferrer">Rotor %28Electric%29</a> attached to the output shaft that is given a torque by the rotating field.
    source:<a href="https://en.wikipedia.org/wiki/AC_motor" target="_blank" rel="nofollow noopener noreferrer">Ac Motor</a>
    In this they haven't mentioned about rotor winding??
  • Mr.Don
    MemberMay 3, 2012
    Wound rotors
    An alternate design, called the wound rotor, is used when <a href="https://en.wikipedia.org/wiki/Adjustable-speed_drive" target="_blank" rel="nofollow noopener noreferrer">Adjustable Speed Drive</a> is required. In this case, the rotor has the same number of poles as the stator and the windings are made of wire, connected to slip rings on the shaft.
    The flux must be cut in order to rotate the motor. The shaft itself cannot rotate.
  • pknaveen17
    MemberMay 3, 2012
    aarthivg
    I have a doubt
    In this case winding is on rotor only and there is no existance of stator.
  • Anthony Jarmie
    MemberMay 5, 2012
    Hello friends,
    The alternator's stator-winding can be damaged if energization persists for a longtime and/or stator-current is much greater than its nominal rating. The rotor field-winding is more likely to suffer because of centrifugal-forces produced during acceleration, or because line-frequency currents are induced into abnormal paths in the rotor-iron and field-winding. On the other hand, insulation-resistance is not likely to deteriorate.
    Thanks a lot
    Anthony
  • Anuj Aggarwal
    MemberMay 10, 2012
    Actually AC motor is of two types
    1. Induction Motor
    2. Synchronous Motor
    In induction motor , stator winding is supplied with 3 phase AC and rotor is wound with armature winding which is neither supplied with AC nor by DC.
    In synchronous motor, stator winding is supplied with 3 phase AC and rotor is wound with DC supplied winding.
