    @thebigk • Jun 19, 2012
    shaikbabu1Could you please suggest some cities to take GRE test where the paper will be somewhat easy..
    GRE is a computer adaptive test. That means, computer will determine the level of difficulty based on your performance in the test. If you answer one question correctly, then the next question will be of somewhat greater difficulty. If you answer a question wrong, then the next question presented to you will be of lower difficulty.
    I doubt whether the level of difficulty depends on the city or center.
  • dikshalakhe
    @dikshalakhe-V2xB4a • Jun 22, 2012
    The_Big_KGRE is a computer adaptive test. That means, computer will determine the level of difficulty based on your performance in the test. If you answer one question correctly, then the next question will be of somewhat greater difficulty. If you answer a question wrong, then the next question presented to you will be of lower difficulty.
    Do you mind me correcting a few things that you mentioned..?
    Now the revised GRE is not question adaptive, it is section adaptive.. If you answer one section correctly, the following section will be difficult and not the consecutive questions.
    I recently appeared for GRE and this is what i get to know from ETS' website..
    And yes, there is no such thing like your paper would be less difficult if you choose a different city or location for your test.. It is online and hence is kept uniform all over..
    @thebigk • Jun 22, 2012
    dikshalakheDo you mind me correcting a few things that you mentioned..?
    Not at all ๐Ÿ˜€ , we're on the quest for correct information. I thought the new GRE keeps the adaptive pattern the same. Thank you for the update.
  • shaikbabu1
    @shaikbabu1-9OTz8Q • Jul 9, 2012
    Oh.. ! Thank you friends..but , some of my friends suggested to take the exam in Hyderabad (Where the paper will be easy )...that's why i asked this question..anyway, thanks once again for clarifying my doubt
  • Manashree Thokal
    @manashree-7mZH3V • Jul 10, 2012
    Yes, it is section adaptive. Center should not matter :/
  • shaikbabu1
    @shaikbabu1-9OTz8Q • Jul 11, 2012
    I got 970 score in GRE's previous pattern ....Can i get any good universities in USA ? My btech percentage was 80% and at present i'm doing job..please reply
