  • reverse gear in motorcycles : feasible ?
    zaveri
    Member
    Updated: Oct 26, 2024
    so what do you guys think of it ? will it involve the generation of a brand new concept all together ?
    is it really necessary ? i thought this idea would be useful , in order to make maneuvering the vehicle easier during parking and eliminate the need for the driver to move it , without hitting his legs against the ground.
    also another situation i considered where this concept would prove to be useful is that when the garage or the parking area has to be entered by moving up a slope, then the driver can clamber it in reverse gear and park his vehicle in the take-off position.
  • mechky
    MemberJun 7, 2012
    zaveri
    Yes, it is feasible. It is used in case of very heavy bikes which are difficult to move manually. As per my knowledge many Harley Davidson bikes have reverse gear. But I'm not aware of any bike in India that has reverse gear.
  • saravanan4
    MemberJun 10, 2012
    i appreciate your idea, but concerning the stasis (stability) of the bike in the reverse and control, will not work out. i saw this because my colleagues have worked out this model and ended in failure..
    AdministratorJun 10, 2012
    Heavy motorcycles may benefit from a reverse gear when you need an extra power to move the vehicle backwards. Technically, it should be possible as I don't see more changes required than a few in gear train (is this right?).
  • vikaskumar11233
    MemberJun 11, 2012
    I also find out this idea as very useful.It will be also helpful in some sloppy area where if our bike started moving in downward direction and break are failed then we can switch gear into back direction and stop our bike .And moreover we should have also try to include hand break.
  • zaveri
    MemberJun 17, 2012
    The_Big_K
    yeah you are right, because as i see in the harley davidson bikes the changes in the gear-box aren't that much.
    but there is one strange thing that i noticed: the kick-start pedal is actually attached to the gear box. now is it connected to the engine through a shaft passing via the gear box ?
