Reverse bias in N Channel JFET
pratap singh, upendra
@pratap-singh-6xlmve โ€ข Oct 25, 2024
hello,
In an n channel JFET why is it that a reverse bias existing between the gate and the source despite the fact that we are shorting the gate and source terminals and keeping Vds as a positive quantity. Now a general explanation would be due to presence of a voltage divider that manifests the properties of the n type conducting channel, but then in that case the bias(between the gate and the source) should have been a positive one. We are applying a positive polarity at the drain(of Vds) and a negative polarity(of Vds) at the source. of course this polarity has nothing to do with the after effects of this biasing method but why this anomaly?
thanks
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Oct 10, 2013
    proffyhello,
    Know this
    Vgs=Vg- Vs
    Where Vg = Voltage at the gate
    Vs = Voltage drop at the source resistor
    When we short the Gate terminal and source we have Vg=0
    This implies Vgs= -Vs
    That explains the negative voltage at gate terminal
  • Jeffrey Arulraj
    You must know that Vs= IdRs
    Id= Drain current which is the same as that off Source current
    Rs= Resistance at the source terminal
    You must know that the drain current is purely because of the Positive voltage at the Vds
