Representing number as sum of smaller numbers
uday.bidkar
@udaybidkar-JNYtYq β€’ Oct 26, 2024
Write a C program that will take a positive integer(N) as input and output
the number of ways that integer can be obtained by adding numbers from 0 to
N.
e.g. If the input is 4, output should be 5 (0+4, 1+3, 1+1+2, 1+1+1+1 and
2+2)
-Uday
  • parag_kulkarni
    @parag-kulkarni-Q8ZhR1 Oct 29, 2007
    Re: Write a C program
    Hi All,
    I almost got the answer😁
    I dont have C compiler available. I have written this program in C#.NET.
    The program works fine except for the fact that it outputs one repeate combination. I am trying to rectify the logic and will post it once i have perfect answer.
    For Example:
    If our input number is 5 then program will output as
    0 + 5
    1 + 4
    1 + 1 + 3
    1 + 1+ 1 + 2
    1 + 1+ 1+ 1 + 1
    1 + 1+ 2 + 1 --> This is extra.
    1 + 2 + 2
    2 + 3
    Regards,
    Parag Kulkarni
    Author: Parag Kulkarni
    using System;
    using System.Collections.Generic;
    using System.IO;
    class Program
    static List<string> list = new List<string>();
    static void Main(string[] args)
    int i = 5; // This is our Input number
    int j = 0, k = i;
    Console.WriteLine(string.Format("{0} + {1} ", j++, k));
    while (j < k)
    k = i - j;
    Console.WriteLine(string.Format("{0} + {1} ", j, k));
    mod(k, j, j.ToString() + " + {0}");
    j++;
    foreach (string str in list)
    Console.WriteLine("{0}", str);
    list.Clear();
    private static void mod(int i, int j, string formatString)
    int k, l;
    l = j;
    if (j > i)
    return;
    else
    k = i - j;
    while (j <= k)
    k = i - j;
    list.Add(string.Format(formatString, string.Format("{0} + {1} ", j, k)));
    mod(k, j, string.Format(formatString, j) + "+ {0}");
    j++;
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z Jul 7, 2009
    I feel this is a good problem statement to code. Any takers?
    -Pradeep
  • shalini_goel14
    @shalini-goel14-ASmC2J Jul 8, 2009
    pradeep_agrawalI feel this is a good problem statement to code. Any takers?
    -Pradeep
    Sure in Java . Please give some time, I will try it in my free and cool time.
    Anyone else ?
  • arihant007
    @arihant007-CJhk9z Jul 8, 2009
    Guys dont you think you are doing wrong. You should help people with errors or bugs in programs. Please don't do their homework. They 'll never improve.
    This is a very easy program.
    I would have helped you, if only you did something and dint know how to go about.
    @thebigk Jul 8, 2009
    @Arihant: The first post comes from an experienced programmer πŸ˜€ I personally know. It's an exercise for the programming students.
  • arihant007
    The_Big_K@Arihant: The first post comes from an experienced programmer πŸ˜€ I personally know. It's an exercise for the programming students.
    oH Ok. Thanks for informing,cause I never really appreciate people outsourcing their homeworks. πŸ˜‰
    No oofense for what i said. ;-)
  • shalini_goel14
    arihant007Guys dont you think you are doing wrong. You should help people with errors or bugs in programs. Please don't do their homework. They 'll never improve.
    Easy? Where is your code then man? One more thing, no one is asking for help in this thread ok. Those who like making programs for enhancing their programming skills only, like fun in making any kind of such programs ok. Unfortunately programmers are rarely seen here πŸ˜”
  • silverscorpion
    @silverscorpion-iJKtdQ Jul 8, 2009
    Ok, cool. He didnt give the code because, as he said, he thought it was a homework.
    May be it is easy.. Who knows. Btw, I'll try to post my code soon. Chill!! πŸ˜€πŸ˜€
  • prasath_amd
    @prasath-amd-NPFUTu Jul 10, 2009
    I'm trying it in both C & Java, i'll post the source & output for both once i'm done.:sshhh:
  • debu
    @debu-62iszV Jul 10, 2009
    Hi Folks!
    This is my version of the solution. I wanted to write a straight, simple and short recursive program, but it turned out to be longer then expected.
    // Program to calculate the number of ways a number can be the sum
    #include "stdafx.h"
    int iNum, iCombinations,iSplitter;
    int iFindSum(int iNumber, int iCombo);
    int _tmain(int argc, _TCHAR* argv[])
        while(1)
            printf("Enter the number: ");
            scanf("%d", &iNum);
            printf("Possible combinations:\n");
            for(iSplitter=1;iSplitter<iNum;iSplitter++)
                iFindSum(iNum, iSplitter);
            printf("Total Combinations=%d\n",iCombinations);
            iCombinations=0;
        return 0;
    int iFindSum(int iNumber, int iBreak)
        if(iBreak>iNumber)
            iBreak-=iNumber;
        if(iNumber<=iBreak)
            printf("%d\n", iNumber);
            iCombinations++;
            return iNumber;
        else
            printf("%d+", iBreak);
            return(iBreak+iFindSum(iNumber-iBreak,iBreak));
    Enter the number: 4
    1+1+1+1
    2+2
    3+1
    Total Combinations=3
    Enter the number: 3
    1+1+1
    2+1
    Total Combinations=2
    Regards,
    Debu πŸ˜€
    Edit: Oops, it seems the program was supposed to be from 0 to N. My code runs from 1 to N. Sorry, I can't be fussed enough to fix it.
  • shalini_goel14
    @shalini-goel14-ASmC2J Jul 10, 2009
    Hi debu,
    Good attempt man πŸ˜€ but I guess for Input =4, there should be 5 combinations. (1+1+2) is missing in your output I guess.[About Program I am not sure. ]
  • uday.bidkar
    @udaybidkar-JNYtYq Jul 11, 2009
    Solution in PHP, (I am loving this language πŸ˜€)
    <?php
    require_onceΒ 'common.php';
    $solΒ =Β array();
    $final_solΒ =Β array();
    $nΒ =Β 4;Β
    Factorize($n);
    foreach(
    $solΒ asΒ $str){
    Β Β Β Β
    $arrΒ =Β explode('+',$str);
    Β Β Β Β
    sort($arr);
    Β Β Β Β
    $final_sol[]Β =Β implode('+',$arr);
    $final_solΒ =Β array_unique($final_sol);
    $i=0;
    foreach(
    $final_solΒ asΒ $str){
    Β Β Β Β
    $i++;
    Β Β Β Β echoΒ
    "$i)$strΒ <br>\n";
    functionΒ
    Factorize($n){
    Β Β Β Β globalΒ
    $sol;
    Β Β Β Β
    Β Β Β Β if(
    $nΒ ==Β 0){
    Β Β Β Β Β Β Β Β
    $sol[]Β =Β "0";
    Β Β Β Β Β Β Β Β return;
    Β Β Β Β }
    Β Β Β Β
    Β Β Β Β
    $sol[]Β =Β "0+$n";Β Β Β Β
    Β Β Β Β if(
    $nΒ ==Β 1){
    Β Β Β Β }
    Β Β Β Β
    GetNaturalFactors($n);
    functionΒ
    GetNaturalFactors($n,$prepend=""){
    Β Β Β Β globalΒ
    $sol;
    Β Β Β Β if(
    $nΒ ==Β 1){
    Β Β Β Β Β Β Β Β
    $sol[]Β =Β $prepend."1";
    Β Β Β Β }
    Β Β Β Β if(
    $nΒ ==Β 2Β ){
    Β Β Β Β Β Β Β Β
    $sol[]Β =Β $prepend."1+1";
    Β Β Β Β }
    Β Β Β Β for(
    $iΒ =Β 1;Β $iΒ <=Β $n/2Β ;Β $i++Β ){
    Β Β Β Β Β Β Β Β
    $sol[]Β =Β "$prepend$i+"Β .Β ($n-$i);
    Β Β Β Β Β Β Β Β if(
    $iΒ <Β $n-$i)
    Β Β Β Β Β Β Β Β Β Β Β Β
    GetNaturalFactors($n-$i,"$prepend$i+");Β Β Β Β Β Β Β Β
    Β Β Β Β }
    Β Β Β Β return;
  • uday.bidkar
    The post still remains open for C program
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z Jul 11, 2009
    @Uday
    Good code buddy, liked the use of available function. Mastering over all languages huh.πŸ˜‰
    @All
    Will wait for few more days, for other to post their code in any language, before posting my code.
    @Debu
    When input is 4, the number of output should be 5 (0+4, 1+1+2) are missing here. When input is 6 your code generate output as:
    1+1+1+1+1+1
    2+2+2
    3+3
    4+2
    5+1
    Total Combinations=5
    Whereas the output should be:
    0 + 6
    1 + 1 + 1 + 1 + 1 + 1
    1 + 1 + 1 + 1 + 2
    1 + 1 + 1 + 3
    1 + 1 + 2 + 2
    1 + 1 + 4
    1 + 2 + 3
    1 + 5
    2 + 2 + 2
    2 + 4
    3 + 3
    0 + 6, 1 + 1 + 1 + 1 + 2, 1 + 1 + 1 + 3, 1 + 1 + 2 + 2, 1 + 1 + 4, 1 + 2 + 3 are missing here.
    The code is not giving all possible results because you are having a for loop which iterates 1 to (N-1), i.e., (N-1) time. And each loop generates a single series which starts from the value of the loop counter and generates sub-sequent numbers with difference of the loop counter (the difference/splitter is set to 1 when the remaining value is less then the loop counter).
    The thing missing here is:
    - There will always a series 0 + N (in this case 0 + 5).6
    - There can be multiple series that start with same value (e.g., 1 + 1 + 1 + 1 + 1 + 1, 1 + 1 + 1 + 1 + 2, 1 + 1 + 1 + 3, 1 + 1 + 2 + 2, and 1 + 1 + 4).
    - There can be series whose difference of subsequent digits might not be same (e.g., 1 + 1 + 2 + 2 and 1 + 2 + 3).
    -Pradeep
  • Sahithi Pallavi
    @sahithi-oJZaYj Jul 11, 2009
    Hi everyone...I tried this program in C...but I am not successfull. can anybody pls help me....
  • pradeep_agrawal
    sahithi pallaviHi everyone...I tried this program in C...but I am not successfull. can anybody pls help me....
    sahithi pallavi, let us know what you have already tried and the point where you are stuck. Also post your code.
    -Pradeep
  • uday.bidkar
    @udaybidkar-JNYtYq Jul 12, 2009
    Remove the "require_once 'common.php';" line from PHP code i posted before trying the code at your end
  • shalini_goel14
    @shalini-goel14-ASmC2J Jul 13, 2009
    Below is what I tried
     * To change this template, choose Tools | Templates
     * and open the template in the editor.
    package myjava;
    import java.io.BufferedReader;
    import java.io.IOException;
    import java.io.InputStreamReader;
    import java.util.HashSet;
    import java.util.Set;
     * @author shalinig
    public class PossibleAdditionCombinationsProgram {
        public static Set<String> additionCombinationsSet= new HashSet<String>();
        public static void main(String[] args) throws IOException{
           BufferedReader br =new BufferedReader(new InputStreamReader(System.in));
           System.out.println("Enter any number:");
           int number=Integer.parseInt(br.readLine());
            System.out.println("0+"+number);
            additionCombinationsSet.add("0+"+number);
            for(int i=1;i<=number;i++){
                String str=Integer.toString(i);
                for(int j=1;j<(number/i);j++){
                    str=str+"+"+Integer.toString(i);
                /* Odd number check */
                 if(number%i!=0){
                        str=str+"+"+Integer.toString(number%i);
                if(str.contains("+") && !additionCombinationsSet.contains(new StringBuilder(str).reverse().toString())){
                additionCombinationsSet.add(str);
                getMoreCombinations(str);
            System.out.println("Possible combinations are:"+additionCombinationsSet.size());
        private static void getMoreCombinations(String str){
            System.out.println(str);
            getMoreReducedFormCombinations(str.split("\\+"));
        public static void getMoreReducedFormCombinations(String []s) {
            String str="";
            int length=s.length;
            int newSecondLastDigit=0;
            int newLastDigit=0;
           if(length >2 && (Integer.parseInt(s[length-1])-Integer.parseInt(s[length-2])<=1)){
                str=s[0];
                for (int i = 1 ; i < s.length-2 ; i++) {
                    str=str+"+"+s[i];
                newLastDigit=Integer.parseInt(s[length-1])+Integer.parseInt(s[length-2]);
                str=str+"+"+newLastDigit;
            } else if(length >2 && (Integer.parseInt(s[length-1])-Integer.parseInt(s[length-2])>1)){
                str=s[0];
                    str=str+"+"+s[i];
                newSecondLastDigit=Integer.parseInt(s[length-2])+1;
                str=str+"+"+newSecondLastDigit;
                newLastDigit=Integer.parseInt(s[length-1])-1;
    If anyone can understand the above program, Please check where I am going wrong that it is missing few combinations for certain numbers. I am also checking if got it, will correct it.
    Thanks !
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z Jul 13, 2009
    @Shalini, i looked into the code. The problem is with the logic of function getMoreReducedFormCombinations.
    As per the logic of the code:
    1. The initial combination that you take consist of all i's (for i = 1 to N) and the remainder at the end.
    2. You call getMoreReducedFormCombinations for each combination you get reduce the combination size till it contains only two numbers.
    3. The logic to you used to reduce the combination size is either you sum up lats two numbers (if difference is <= 1) or subtract 1 from last digit and add 1 to second last digit.
    You code work till N = 7 but skip some entries when N >= 8. Let's see why it creates problem for N >=8.
    For N=8, the output should have been 22 entries as:
    0+8
    1+1+1+1+1+1+1+1
    1+1+1+1+1+1+2
    1+1+1+1+1+3
    1+1+1+1+2+2
    1+1+1+1+4
    1+1+1+2+3
    1+1+1+5
    1+1+2+2+2
    1+1+2+4
    1+1+3+3
    1+1+6
    1+2+2+3
    1+2+5
    1+3+4
    1+7
    2+2+2+2
    2+2+4
    2+3+3
    2+6
    3+5
    4+4
    Whereas, your code give output 20 entries as:
    0+8
    1+1+1+1+1+1+1+1
    1+1+1+1+1+1+2
    1+1+1+1+1+3
    1+1+1+1+2+2
    1+1+1+1+4
    1+1+1+2+3
    1+1+1+5
    1+1+2+4
    1+1+3+3
    1+1+6
    1+2+5
    1+3+4
    1+7
    2+2+2+2
    2+2+4
    2+3+3
    2+6
    4+4
    5+3
    The entries missing here are "1+1+2+2+2" and "1+2+2+3".
    As per the logic of your code (what i mentioned in step 3 above), the combination size is reduced by manipulating only last two digits. But the logic does not take care that the combination can also be obtained by manipulating digits other then last two digits.
    E.g., when you got combination "1+1+1+1+2+2", the code reduced it by adding the last two digits and giving a new combination "1+1+1+1+4" but a new combination can be obtained by adding third and fourth last digits as "1+1+2+2+2".
    Similarly, when you got combination "1+1+1+2+3", the code reduced it by adding the last two digits and giving a new combination "1+1+1+5" but a new combination can be obtained by adding third and fourth last digits as "1+2+2+3".
    The code only output those entries where except last two digits all other digits are always i's (for i = 1 to N) and any entry which does not follow this pattern (e.g., "1+1+2+2+2" and "1+2+2+3") will be missing.
    Improving the logic of code to handle this will fix the issue.
    -Pradeep
  • shalini_goel14
    @shalini-goel14-ASmC2J Jul 14, 2009
    Cool man. I got it where I was going wrong. Will try it as soon as get some better time.
    Thanks a lot !
    PS: Still looking for a better logic. πŸ˜”
  • safwan
    @safwan-NH7W5Y Jul 14, 2009
    I know many forums that say like same as you you might be knowing this but i know what you say is correct
    why cant we give a logorithem in words adn then putting it on coding .
  • safwan
    yes ! give me some more time just to get ridof exame and itill saturday ill post (as just to get logi and time)
    Is VB alllowed ?
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z Jul 14, 2009
    safwanIs VB alllowed ?
    You can post solution in any language of your choice.
    -Pradeep
  • mech_guy
    @mech-guy-TMwuj2 Jul 15, 2009
    Hi,
    Here is my attempt. Am not good at programming in C++ (as can be seen from length of code and coding itself) , so i will appreciate all comments/critics from some of the cool programmers i have seen at CE.
    #include <iostream>
    #include <string>
    using namespace std;
    int nfact1, nfact2;
    char factor1[512][512], factor2[512][512];
    int main()
        int factorize(int, int, char*);
        int N, n1, n2, n;
        char a1[512], a2[512], a3[512];
        cout << "Please enter the number to be factorized:\t";
        cin >> N;
        if (N == 1) {
           cout << "1.\t0 + 1\n";
           cout << "Number of factors:\t1\n";
        else if (N == 2) {
           cout << "1.\t0 + 2\n";
           cout << "2.\t1 + 1\n";
           cout << "Number of factors:\t2\n";
        else {
           nfact1 = 1;
           char a[] = "1 + ";
           n1 = 1;
           sprintf(a1,"%d",n1);
           strcpy(a2,a);
           strcat(a2,a1);
           strcpy(factor1[0],a2);
           for(int i=3; i<=N; i++) {
              char a[] = "1 + ";
              n1 = i - 1;
              strcpy(a2,a);
              strcat(a2,a1);
              nfact2 = 1;
              strcpy(factor2[0],a2);
              for (int j=0; j<nfact1; j++) {
                 nfact2++;
                 strcpy(a2,a);
                 strcat(a2,factor1[j]);
                 strcpy(factor2[nfact2-1],a2);
              if (i%2 == 0) n = i/2;
              if (i%2 != 0) n = (i-1)/2;
              int j = 2;
              while (j <= n) {
                 n1 = i - j;
                 sprintf(a,"%d",j);
                 strcat(a," + ");
                 sprintf(a2,"%d",n1);
                 strcpy(a3,a);
                 strcat(a3,a2);
                 nfact2++;
                 strcpy(factor2[nfact2-1],a3);
                 if (n1%2 == 0) n2 = n1/2;
                 if (n1%2 != 0) n2 = (n1-1)/2;
                 if (n2 >= j) factorize(n1,j,a);
                 j = j + 1;
              nfact1 = nfact2;
    // cout << "Factors of " << i << endl;
              for (int j=0; j<nfact2; j++) {
                 strcpy(factor1[j],factor2[j]);
    // cout << j+1 << ".\t" << factor1[j] << endl;
        cout << "Factors of " << N << endl;
        cout << "1.\t" << "0 + " << N <<endl;
           cout << j+2 << ".\t" << factor1[j] << endl;
        cout << "Total combinations: " << nfact1+1 << endl;
        /* Scaffolding code for testing purposes */
        cin.ignore(256, '\n');
        cout << "Press ENTER to continue..." << endl;
        cin.get();
        /* End Scaffolding */
    int factorize(int N, int n, char*a1)
        int n2, n1, N1;
        char a2[512],a[512],a3[512],a4[512];
        strcpy(a,"\0");
        if (N%2 == 0) n1 = N/2;
        if (N%2 != 0) n1 = (N-1)/2;
        int j = n;
        N1 = N;
        while (j <= n1) {
           n2 = N1 - j;
           sprintf(a4,"%d",j);
           strcat(a,a4);
           strcat(a," + ");
           strcpy(a4,a);
           strcat(a4,a1);
           sprintf(a2,"%d",n2);
           strcpy(a3,a4);
           strcat(a3,a2);
           nfact2++;
           if ((n2-j) >= n) N1 = n2;
           if ((n2-j) < n) {
              j = j+1;
              if (j > n1) break;
              if (j <= n1) {
                 N1 = N;
                 strcpy(a,"\0");
    Output for 8:-
    Please enter the number to be factorized: 8
    Factors of 8
    1. 0 + 8
    2. 1 + 7
    3. 1 + 1 + 6
    4. 1 + 1 + 1 + 5
    5. 1 + 1 + 1 + 1 + 4
    6. 1 + 1 + 1 + 1 + 1 + 3
    7. 1 + 1 + 1 + 1 + 1 + 1 + 2
    8. 1 + 1 + 1 + 1 + 1 + 1 + 1 + 1
    9. 1 + 1 + 1 + 1 + 2 + 2
    10. 1 + 1 + 1 + 2 + 3
    11. 1 + 1 + 2 + 4
    12. 1 + 1 + 2 + 2 + 2
    13. 1 + 1 + 3 + 3
    14. 1 + 2 + 5
    15. 1 + 2 + 2 + 3
    16. 1 + 3 + 4
    17. 2 + 6
    18. 2 + 2 + 4
    19. 2 + 2 + 2 + 2
    20. 3 + 2 + 3
    21. 3 + 5
    22. 4 + 4
    Total combinations: 22
    Code will be limited for numbers upto 22, else might have to increase size of arrays.
    If there is a way out to know beforehand, the total combinations possible for a given number then it would be easier (to code and also cross-verify the answer).
    Regards
  • pradeep_agrawal
    @pradeep-agrawal-rhdX5z Jul 19, 2009
    Good work buddy, now we have one working code 😁
    I have few suggestions:
    1. I feel the cout and for loop at the end of main function should be inside the last else statement of the main function.
    2. Avoid use of global variables, you will have many advantages (e.g., the code will be more reusable).
    3. Running the code for N=22 gives error at the end of execution. This might be because for N=22 the total number of combinations are 558 and the array factor1 can hold only 512 entries. So you are writing on memory not allocated to the array. To avoid such issues use dynamic memory allocation.
    4. The code has heavy use of string operations and large number of temporary variables which can be reduced, e.g.,
    char a[] = "1 + ";
    n1 = 1;
    strcpy(a2,a);
    strcat(a2,a1);
    can be modified to
    strcpy(factor1[0],"1 + 1");
    char a[] = "1 + ";
    n1 = i - 1;
    strcpy(a2,a);
    strcat(a2,a1);
    can be modified to
    n1 = i - 1;
    sprintf(factor2[0],"1 + %d",n1);
    sprintf(a,"%d",j);
    strcat(a," + ");
    strcpy(a3,a);
    strcat(a3,a2);
    can be modified to
    sprintf(factor2[nfact2-1],"%d + %d",j, n1);
    -Pradeep
  • pradeep_agrawal
    Below is my solution to the problem:
    #include "stdio.h"
    void displayseries(int* series, int count) {
      int i = 0;
      if(count != 0) {
        for(i = 0; i <= count; i++) {
          if(i == count) {
            printf("%d\n", series[i]);
          } else {
            printf("%d + ", series[i]);
    int find_sum_series(int num, int* series, int count, int sum) {
      int starting_number = 0;
      int combination_count = 0;
      if(count < 0) {
        starting_number = 1;
      } else {
        starting_number = series[count];
      while((sum + starting_number) <= num) {
        if((sum + starting_number) < num) {
          count++;
          series[count] = starting_number;
          sum += starting_number;
          combination_count += find_sum_series(num, series, count, sum);
          count--;
          sum -= starting_number;
        } else if((sum + starting_number) == num) {
          count++;
          displayseries(series, count);
          combination_count++;
          count--;
        starting_number++;
      return combination_count;
    int main() {
      int *series = NULL;
      int count = 0;
      int num = 0;
      scanf("%d", &num);
      if(num < 1) {
        printf("Invalid number\n");
        return 0;
      printf("Combinations:\n", num);
      printf("0 + %d\n", num);
      series = (int*)malloc(sizeof(int) * num);
      count = find_sum_series(num, series, -1, 0);
      printf("Total combinations: %d\n", count);
      free(series);
      return 0;
    Compile the file with above code and run as:
    a.exe < input.txt > output.txt [on windows]
    a.out < input.txt > output.txt [on linux]
    Here,
    a.exe or a.out are the executables generated after compilation
    input.txt is the file containing input, e.g., if the number is β€˜5’ then input.txt will be:
    5
    output.txt is the output file containing result, for given example output.txt will contain:
    Combinations:
    0 + 5
    1 + 1 + 1 + 1 + 1
    1 + 1 + 1 + 2
    1 + 1 + 3
    1 + 2 + 2
    1 + 4
    2 + 3
    Total combinations: 7
    -Pradeep
  • pradeep_agrawal
    @mech_guy
    I was comparing the results of your code with the results of my code. Your code worked fine till N=10. But after that it skipped few entries, e.g.,
    For N=11
    The output of code was 55 combinations whereas the total combinatipns possible are 56 ("2 + 2 + 3 + 4" combination was missing in output).
    -Pradeep
  • mech_guy
    @mech-guy-TMwuj2 Jul 20, 2009
    Hi Pradeep,
    Thanks a lot man for your comments. Will go through all (one by one) πŸ˜€
    Yup, i got it. (2+2+3+4) must have been missed (never thought about this poor fellow).
    Thanks a lot again and would go through your comments and your code too (looks wow to me).
    Any chance that we could know beforehand about "Total number of combinations" for a given number. Atleast if one knows that one could cross-verify his/her code.
    Regards
