  • Replacing Bearings
    ABCD ABCD
    Member
    Updated: Oct 25, 2024
    Views: 1.1K
    When exactly should we replace the bearings of vehicle wheels? How to know whether bearings are to be replaced? What exactly/How exactly ball bearings work in Cars and other vehicles?
    Refer: Hstuffwork... I want some discussion to understand clearly.
  • ISHAN TOPRE
    MemberJun 18, 2011
    Hello eccentric,
    The bearings are for supporting shafts. The material for bearings are soft as compared to shaft. The bearings are mostly made from cadmium base alloys.
    For normal bearings see this as you recommended: <a href="https://science.howstuffworks.com/transport/engines-equipment/bearing3.htm" target="_blank" rel="nofollow noopener noreferrer">Types of Bearings - How Bearings Work | HowStuffWorks</a> Well the diagram itself is self explanatory. Regarding automobiles, let us wait for people to comment. 😀
  • ABCD ABCD
    MemberJun 18, 2011
    ishutopre
    Hello eccentric,
    Yes, but the question is how bearings are useful in proper movement of vehicle. I referred the HSW link, but req some discussion for me to understand.
    For Ex: Consider the diff between normal wheel(with bearings) and one without bearings. What difference does it make to the wheels?
  • sumit gupta
    MemberJun 22, 2011
    whn shaft will vibrate and producing noice thn bearing will replace
  • gohm
    MemberJun 23, 2011
    If you are refering to hub bearings, you can check for freeplay by shaking the wheel. Automobiles tend to use other forms of bearings than standard ball bearings, like: roller, bushing, fluid & needle.
