REMOTE ALIGNMENT OF 3D DISH POSITIONING BY ANDROID APPLICATION
@maur-bawankatr-dq0c3Q
1.9K
Project Abstract / Summary : The project is designed to develop a dish positioning system which can be operated by using an Android application. The main application of using a dish is to receive signal from satellites and other broadcasting sources. In order to position the dish to the exact angle to receive the maximum signal of a particular frequency, it needs to be adjusted manually.
In order to overcome the difficulty of adjusting manually, this proposed system helps in adjusting the position of the dish through an Android application device. Remote operation is achieved by any smart-phone/Tablet etc., with Android OS, upon a GUI (Graphical User Interface) based touch screen operation. This system consists of two motors that enable the dish to move both in horizontal and vertical direction. The Android application device acts as a transmitter whose data is received by Bluetooth device which is interfaced to a microcontroller of 8051 family. The Bluetooth device sent data to the microcontroller which is transmitted from Android application device. The microcontroller sends control signals to the motors through an interface IC also known as motor driver IC. The Bluetooth device serially communicates with the microcontroller.
Why did you choose to work on this project topic : The project is designed to develop a dish positioning system which can be operated by using an Android application. And till now no one can rotated antenna by android app
An electronic dish position control system is made up of two motors that enable the dish to rotate both in horizontal and vertical direction, remotely controlled by infrared means
Institute/College Name: S.B. Jain Institute of Manaagment Technology Research,Nagpur
City: Nagpur
State: Maharashtra
City: Nagpur
State: Maharashtra
