Registry tweaks
sbscetferozpur
@sbscetferozpur-V9HVvl Oct 26, 2024
Use the information at your own risk.
[Start] [Run] [Regedit]
Goto Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
Modify/Create the Value Name [Window Title] according to the Value Data listed below.
Data Type: REG_SZ [String Value] // Value Name: Window Title
Value Data: [Enter The Text Desired In Title Bar]
Exit Registry and Reboot....
Make the Administrator Account Always Visible on the Login Screen
Registry Key: HKEY_LOCALMACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts\UserList.
Modify/Create the Value Data Type(s) and Value Name(s) as detailed below.
Data Type: DWORD// Value Name: Administrator.
Setting for Value Data: [0 = Disabled / 1 = Enabled].
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Mar 25, 2010
    Change the Registered Organization/Owner of Windows XP
    Registry Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
    Data Type: String Value // Value Name: RegisteredOrganization.
    Data Type: String Value // Value Name: RegisteredOwner.
    Setting for Value Data: [Modify the Values to Reflect Current Information]
  • sbscetferozpur
    share your experience also......
  • Manish Goyal
    @manish-r2Hoep Mar 25, 2010
    Quite nice information buddy
    but i recommend don't mess with registry settings..
  • sbscetferozpur
    Enable/Disable System Properties Access from My Computer - Current User
    Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Data Type: REG_DWORD [Dword Value] // Value Name: NoPropertiesMyComputer
    Value Data: [0 - Display Properties / 1 - Hide Properties]
    Enable/Disable System Properties Access from My Computer - Local Machine
    Registry Key: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Exit Registry and Reboot.....
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Mar 26, 2010
    Copy To ContextMenuHandlers
    Registry Key:HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers.
    Create a new Key. Name the new Key: Copy To
    In the right-hand pane, double click the existing REG_SZ called Default, and set the value to:
    {C2FBB630-2971-11d1-A18C-00C04FD75D13}
    you do need the {curly brackets} for this CLSID.
    Close regedit, no need to reboot or even logoff.....
  • sbscetferozpur
    Get Rid of the Arrows on Shortcuts
    Registry Key:HKEY_CLASSES_ROOT > lnkfile
    rename ‘IsShortcut’ to ‘AriochIsShortcut’ in the right pane
    exit regedit and reboot.....
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Mar 30, 2010
    Sometimes, your path when you go to start->run, CMD will be something you don’t want. In active directory or on an NT domain, sometimes your default home path might be a network drive. This isn’t so good when you are offline or drop offline after being online. The CMD prompt is set to a place where you can’t get to.
    To change the path, you can edit the registry
    Registry Key:
    [HKEY_CURRENT_USER\Software\Microsoft\Command Processor]
    “Autorun”=”c:”
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Apr 5, 2010
    Disabling the Right-Click on the Start Button ​Normally, when you right button click on the Start button, it allows you to open your programs folder, the Explorer and run Find.
    In situations where you don't want to allow users to be able to do this in order to secure your computer.
    1.Open RegEdit
    2.Search for Desktop
    3.This should bring you to HKEY_CLASSES_ROOT\Directory
    4.Expand this section
    5.Under Shell is Find
    6.Delete Find
    7.Move down a little in the Registry to Folder
    8.Expand this section and remove Explore and Open
    Now when you right click on the Start button, nothing should happen.
    You can delete only those items that you need.
  • sbscetferozpur
    Show administrator account on welcome screen
    Registry Key:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts\UserList
    Add the DWORD value 'Administrator' with a value of '1' ...
    exit and reboot........
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Apr 8, 2010
    Registry Key:HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer
    rename link, with a value of 00 00 00 00.
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Apr 13, 2010
    Show Windows version on desktop
    Registry Key: HKEY_CURRENT_USER\Control Panel\Desktop..
    Create a new DWORD " PaintDesktopVersion" and change its value to "1" for showing and "0" for removing.
  • sbscetferozpur
    Change the Title of windows madia player
    Registry Key:HK_C_USER\software\policies\microsoft\windows medi aplayer
    Create a new string value called ' TitleBar' and change text as your wish.
    exit and enjoy....
  • meeran
    @meeran-rxMtFb Apr 14, 2010
    Sorry Guys......... I am a novice in these Registry Games........ Please post many such Registry Tweaks..... Its very usefull....
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Apr 15, 2010
    Remove "Log off" from start menu
    "HKEY_CURRENT_USER\Software\Microsoft\Windows\ Curr entVersion\Policies\Explorer"
    and
    "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows \Cur rentVersion\Policies\Explorer"
    Create a new DWORD "NoLogOff" and change its value to "1" for disabling and "0" for enabling.
  • sbscetferozpur
    @sbscetferozpur-V9HVvl Apr 16, 2010
    Registry Key:HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
    Create a new 32-bit DWORD value in the right hand pane with these values
    Value: 1
    reboot and enjoy...
  • ankesh.cs2007
    @ankeshcs2007-GnaFEW Apr 19, 2010
    for more registry tweeks go to thread tips n tricks
