Reg: contactless sensors for liquids
barath rajamani
barath rajamani
@barath-uBS8aH Oct 20, 2024
hey all
i am was thinking about making a contact-less sensor to measure the amount of diesel in a open tank. i need a 0-10V DC input from the sensor so that i can take it to the PLC or any other things. i get the idea with the ball valve concept but to get the 0-10VDC calibrated is something i don't know. or is there any other simpler idea.
Kindly clarify
  • chithrachennai
    chithrachennai
    @chithrachennai-Xvts5V Aug 13, 2012
    u can use optical sensor but its lil costly... uv sensor is also there...
    Ramani Aswath
    @ramani-VR4O43 Aug 13, 2012
    Freescale semiconductors situated on the ring road between Marathhalli and KR Puram have a range of MEMS based pressure sensors. You can easily put together an PLC compatible system that can measure liquid level. I use them a lot for various biomedical applications.
    However, if you are considering for diesel I would design an indirect non invasive system using the same sensor but with an inert gas intermediate stage to avoid any fire hazard.
  • barath rajamani
    barath rajamani
    @barath-uBS8aH Dec 7, 2012
    thank you but for industrial harsh conditions and for diesel related issues, we would not go for MEMS, i think (or can we?)... but i am working on a DIY stuff for this.. will see if itworks out..
  • lal
    lal
    @lal-R60Xjx Dec 7, 2012
    -deleted-
    Reason: Replied without reading previous posts 😐 came to know that I repeated the same thing said above.
    Ramani Aswath
    @ramani-VR4O43 Dec 7, 2012
    bobgalle
    I am currently using one of these for sensing steam pressure for a sterilizer. To avoid steam and condensate from reaching the sensor I have used a small diameter silicone rubber tube filled with silicone oil at the sensor end. No problem in the two years use so far.
