Recommend motor driver for line following robot
Powerful
@powerful-D9Kwma • Oct 26, 2024
What motor driver would you recommend for my line following robot. I am using geared motors...(if that is of any help!!!)..
Thank you.
  • preeste
    @preeste-Q3d5XK • Nov 21, 2007
    hi there....look i dont know if this of any help....but take a look at the other forums on line followers....it might help!
    from my research the L293D seems to be quite common and often used one.
  • reachrkata
    @reachrkata-FOcqhH • Nov 21, 2007
    I am not sure of what load you are expecting for the motors (depends on ur robot).
    I have worked a bit on CD drives, which use motors for the Load/Eject, disk rotation and the Reading head movement.
    For this they normally use BA5813FM or BA5983FM (or similar) from ROHM.
    These are 4 channel motor drives, so you can control more motors with a signle driver IC.
    Karthik
  • harshharsh26
    @harshharsh26-rIc2Z4 • Nov 30, 2007
    L293D will be best I have used it many time , Its quiet easy to implement...
  • Ashraf HZ
    @Ash • Nov 30, 2007
    yep, L293 is a good choice.
  • caen_clux
    @caen-clux-KJ4RAe • Dec 4, 2007
    Line following robot- driver motor
    Actually you must know how much maximum current of the motor..then you can decide what is the suitable driver can be used.For your information,if your motor use less than 1Amp, you can use driver L293B.Its will support the current maximum up to 1Amp...for further knowledge about line following visit at https://robotku.blogspot.com.
