Rack Pinion designing
Mohit Kamat
Mohit Kamat
@mohit-kamat-g7XEx9 Oct 27, 2024
I'm designing a steering wheel mechanism on solid works. But once assembled, two teeth of the pinion on both side of the tooth and groove which are in contact are entering into the teeth of the rack, thus making it a single part all together. Though I've understood that it is happening because of the wrong angle of the teeth on the rack, I'm unable to solve this problem efficiently.
I've set 30 teeth on the pinion (which I placed on the sides of a polygon with 30 sides). I took the measurement of the side of the polygon (i.e base of the teeth again) and made a linear pattern of teeth on the rack with the same distance as base. But now I understand that I overlooked the angle of teeth on the rack...PLEASE HELP!!!!!
  • Mohit Kamat
    Mohit Kamat
    @mohit-kamat-g7XEx9 Aug 18, 2012
    Please Help
  • zaveri
    zaveri
    @zaveri-5TD6Sk Aug 20, 2012
    What can be done, dude
    Ramani Aswath
    @ramani-VR4O43 Aug 20, 2012
  • CE Designer
    CE Designer
    @ce-designer-BWq0yl Aug 21, 2012
    If you mated the two parts properly and the teeth are identical then it should work fine. Is your problem the design of the rack teeth on Solid Works?
  • mechky
    mechky
    @mechky-jbqpJD Aug 21, 2012
    Mohit Kamat
    I'm not able to understand your problem clearly. It would be best if you can post some screenshot or video of the simulation.
  • Mohit Kamat
    Mohit Kamat
    @mohit-kamat-g7XEx9 Aug 27, 2012
    actually the problem is i haven't created a profile for the teeth(triangular)...this is what i studied...had no idea about this profile thing...was trying to mesh the gears only by dimensions and angles...and so wanted to know how to do it
