Questions about DC Machines
sreekant
@sreekant-Vj0Hjj Oct 25, 2024
what is the relation between speed and armature current?,flux vs armature current?what happens to flux,armature current,speed,torque if the load increases??
  • AMITBOSE
    @amitbose-3q0iVf Sep 2, 2009
    Re: dc machines
    U can refer ashfaq hussain book
  • vishnu priya
    @vishnu-priya-L6wLMl Sep 2, 2009
    Re: dc machines
    AMITBOSEU can refer ashfaq hussain book
    More details please!!!
  • Mr.Don
    @mrdon-92OwlG Sep 2, 2009
    Increase in flux decreases the speed but increases the torque. If torque is decreased by decreasing the field current the following sequences are found:
    1. <a href="https://en.wikipedia.org/wiki/Counter-electromotive_force" target="_blank" rel="nofollow noopener noreferrer">Counter Electromotive Force</a> drops instantly, the speed remaining constant because of the inertia of heavy armature.
    2. Due to decrease of EMF armature current I is increased because of I = (V − E)/R.
    3. A small decrease of flux is more than counterbalanced by a large increase of I which means net increase of torque.
    4. If torque increases the speed also increases.
    If applied voltage is kept constant, motor speed has inverse relation with flux.
    [​IMG] where:
    • N = revolutions per minute .i.e. motor speed
    • K = proportional constant
    • R = resistance of armature (<a href="https://en.wikipedia.org/wiki/Ohm" target="_blank" rel="nofollow noopener noreferrer">Ohm</a>)
    • V = electromotive force (<a href="https://en.wikipedia.org/wiki/Volt" target="_blank" rel="nofollow noopener noreferrer">Volt</a>)
    • I = current (<a href="https://en.wikipedia.org/wiki/Ampere" target="_blank" rel="nofollow noopener noreferrer">Ampere</a>)
    • Φ = flux (<a href="https://en.wikipedia.org/wiki/Weber_%28unit%29" target="_blank" rel="nofollow noopener noreferrer">Weber %28Unit%29</a>)
  • Mr.Don
    You will know it clearly by doing lab exercises perfectly..
  • ashutoshglamour
    @ashutoshglamour-YcpJXd Sep 3, 2009
    You can find the answers in book-B.L.THEREJA
  • cowboy
    @cowboy-SpjNiz Sep 3, 2009
    I can find answer in any electrical machine book like b.L.Thareja volume 2.
