Question - Mass, Density and Volume
Lance Michael Farrar
@lance-michael-farrar-5J1nuI โ€ข Oct 27, 2024
I need some info. A single atom of Carbon has a Mass, Density and Volume at room temperature. How do these change when that Atom is moved to a temperature of -253c. Example; If the Mass, Density and Volume were each arbitrarily given the value of 1 at room temperature - what {if any} would be the % of change when that Atom is moved to -253c?
    @ramani-VR4O43 • Sep 2, 2015
    A single atom does not have a density as defined for bulk matter.
  • Lance Michael Farrar
    @lance-michael-farrar-5J1nuI • Sep 2, 2015
    What about Volume?
    Does it have Volume and if so does that change?
    This may help:
    @lance-michael-farrar-5J1nuI • Sep 3, 2015
    Thank you.
    A.V.RamaniThis may help:
    Thank you. I didn't see a reference to temperature in the equations. Does that mean that an atom of Carbon has the exact same volume at -253c as it does at room temperature? The reason for asking is that if the volume is lower at -253c then more of them can be held in a smaller space. If they can be contained within that space and brought up to room temperature then the product would have a higher density. Thanks again, Lance
    @ramani-VR4O43 • Sep 4, 2015
    The volumetric coefficient of thermal expansion for diamond is about 0.000003 which means that at -253degC it will contract to (1 - 0.000760) times the volume at 0 degC.
    @lance-michael-farrar-5J1nuI • Sep 4, 2015
    It sounds like the volume of a single Carbon atom at room temperature is the same whether it is in the form of a lump of coal or in a Diamond. and it is also the same at -253c.
    The volume of a single carbon atom is the same whether it is in a Diamond or piece of coal?
    Coal is a mix of various things, not just carbon.
    [โ€‹IMG]
    This gives specific info on the various carbon allotropes:
    Thank you for your input.
