  • Query about Electromagnet
    HRG
    Member
    Updated: Oct 27, 2024
    Views: 1.0K
    iam tryin to make an electromagnet that operates under 12 volt dc😀
    .i want to know how many turns of copper wire i should wound over an iron piece (eg. iron nail) so that it would be able to lift a finger- size bolt &nut😎.i use the copper wire taken from a ordinary 6 volts motor coil.
    members am awaiting for your responses..😒 .
    Iron nails come in all sorts of sizes. Better use a large dia (>4 mm) and about 80 to 100 mm long one. Use a length that will give a resistance of 9 to 15 ohms. You may need about 40 meters length of 0.25 mm dia copper wire. This will give ample magnetic pull.
  • HRG
    MemberNov 29, 2011
    Thank you sir
