    @harshad-ukH5ww Aug 29, 2010
    Are you using Timer to generate the PWM then just reload the different Timer Value and that will give you the PWM waveform.
    In PWM you have to set the TON and TOFF time period say keep PIN ON for xx second and OFF for yy seconds generate this xx and yy seconds using Delay function or usinf Timer.
    Hop you will get the idea for PWM.
