puzzle for you
aditi
@aditi-YUhZ1S โ€ข Oct 25, 2024
hi.... try this puzzle
there are two solutions containing water & milk in the ratio 1:4 & 1:5.
now they mixed. so what is the ratio of water & milk in new solution
the given choices..
a) 2:9 b)5:9 c)9:20 d)5:20
  • rick
    @rick-JybHX8 • Aug 9, 2006
    aditihi.... try this puzzle
    the given choices..
    Let there be 30 litres of each solution.
    So quantity of Water & Milk in first solution is 6 litre & 24 litre, respectively.
    similarly, quantity of Water & Milk in second solution is 5 litre & 25 litre, respectively.
    If the two solutions are added, total quantity of solutions = 60 litre.
    Qutantity of water = 6 + 5 = 11 litre.
    Quantity of milk = 24 + 25 = 49 litre.
    Required ratio = 11/49
    ๐Ÿ˜’ ... have you verified the options?
    Rick
  • aditi
    @aditi-YUhZ1S • Aug 9, 2006
    i tried and got the same ans as yours but it is not in the option..๐Ÿ˜•
  • rick
    Don't worry, the options are wrong ๐Ÿ˜ . The approach is right and all the steps are right. The answer has to be right !
    Rick
  • karthick200621
    @karthick200621-RrhcbO • Aug 9, 2006
    result
    water : 1/5 + 1/6
    milk : 4/5 + 5/6
    answer : 11: 49
    no option there
    always try to do it simple and save time
  • aashima
    @aashima-eO93l9 • Aug 9, 2006
    well
    i too got the same answer as 11:49 ๐Ÿ˜” aditi i suppose there lies some fault in the question only then.
  • Neha
    @neha-3vibjn • Aug 10, 2006
    Same here,even I got the answer as 11:49..check the options again.
    Aditi,u can use the thread aptitude for such questions and your problems.
  • Anil Jain
    @CrazyBoy • Aug 13, 2006
    nehaSame here,even I got the answer as 11:49..check the options again.
    I am pretty sure that there is no crap in this question...
    Only Choice's are wrong...
    Just explainnig a bit why rick take 30 liters in his assumption...
    in first solution ratio is 1:4 so (total 5 say..) in second solution ratio is 1:5 (total 6 say..) and to reduce the fractions calculation he tool the LCM of 5 and 6 so it will reduce his calculations...
    Hey post answer...and A new question too with correct answer choices
    @thebigk • Sep 23, 2006
    ((bumpp))
    Dead thread. We are low on math puzzles again ๐Ÿ˜
    -The Big K-
  • integratdbrains
    @integratdbrains-8bmazm • Sep 23, 2006
    I think the answer is
    rickLet there be 30 litres of each solution.
    Rick
    I don't know how i missed this one but I think rick u are exactly on the right track but the point where my solution differs is if you are considering 1part of water as 6 for the first solution then why are you taking the same unit i.e. 1 unit of same liquid i.e. water as 5 in the other solution? So worked it out that way it will come to 2:9 which exists in the options provided. so aditi whats the answer? i think its long time plz post in the answer.๐Ÿ˜
  • Jerry
    @jerry-5wPKU7 • Sep 25, 2006
    integratdbrainsI don't know how i missed this one but I think rick u are exactly on the right track but the point where my solution differs is if you are considering 1part of water as 6 for the first solution then why are you taking the same unit i.e. 1 unit of same liquid i.e. water as 5 in the other solution? So worked it out that way it will come to 2:9 which exists in the options provided. so aditi whats the answer? i think its long time plz post in the answer.๐Ÿ˜
    I could not get your point. I think Rick has the perfect answer. How did you get 2:9 ?
    Jerry
  • integratdbrains
    @integratdbrains-8bmazm • Sep 25, 2006
    wait for the answer
    Actually jerry i donot claim to be correct so lets wait for aditi to post the answer then if its correct i will surely post in the solution! ๐Ÿ˜€
  • Mayur Pathak
    @mayur-ywQKfu • Sep 25, 2006
    right answer
    correct answer is 2:9
    I think explaination by integratd brains is right.
  • aditi
    @aditi-YUhZ1S • Sep 27, 2006
    hi all......
    i dont know the answer.. i found it somewhere and thought to put it on ce...
    @thebigk • Sep 27, 2006
    Math Guru drops in
    (bump) (bump)
    Math Guru drops in ๐Ÿ˜Ž ! I noticed that we have conflicting solutions for a stupid math problem and decided to separate milk & water.
    The trouble starts here -
    Does the problem mention that we have "equal quantities" of both the solutions? Why assume?
    The problem is as simple as
    "1 part of milk from first solution mixes with 1 part of milk from second solution"
    "4 parts of water mix with 5 parts of water from second solution"
    Therefore, the new solution will have Milk:Water :: 2:9 ๐Ÿ˜
    I hope this helps. Remember: Keep It Simple & Stupid!
    -The Big K-
  • Mahesh
    @mahesh-wLPhv2 • Oct 7, 2006
    Hi Biggie,
    Can u explain same soln if we take equal quantities that to same 30L?
    @thebigk • Oct 7, 2006
    MaheshHi Biggie,
    Mahesh, the problem does not talk about equal quantities. The reasoning by Rick is perfect except that we cannot have equal quantities of the solutions.
    -The Big K-
  • gautyaaa
    @gautyaaa-OEiypT • Feb 13, 2007
    correct answer is 2:9......
    in 1st sol.
    water----->1lt
    milk---->4lt
    in 2nd sol.
    water---->1lt
    milk---->5lt
    total---->11lt.
    check in d options ---->2+9==11๐Ÿ˜Ž
    how can u question d question....lol๐Ÿ˜
