Pump Calculations
Khartz Di
@khartz-di-5entBw โ€ข Oct 27, 2024
A farmer uses a centrifugal pump to pump the river water to a storage tank located in his farm 20 m above the river . If the water is filled in the tank at the rate of 15 L/s and frictional losses in the pipe is 0.5m. Calculate how much extra he has to pay for his monthly electricity bill (30days) while running the pump for 6 hours daily. The motor and pump efficiency is 70% and cost of electricity is 38 c /KWH.
can any one briefly explain how to do this problem?????
  • Ammar Aziz
    @ammar-aziz-7MLZYl • Sep 28, 2012
    please describe frictional losses in correct units
    @ramani-VR4O43 • Sep 28, 2012
    Ammar Azizplease describe frictional losses in correct units
    That is the correct unit. Head of water in metres.
  • Ammar Aziz
    but sir please explain me that what is the meaning of o.5m frictional losses
    If you look at the Bernoulli's equation, everything is converted into equivalent height of liquid column. In the present case, the 0.5 m is about 2.5% of the differential head of 20 meters. The implication is that the pump is raising the water not by 20 m but by 20 m + 0.5 m (friction head). In effect the pump consumes proportionately that much more power.
    Incidentally, this is not included in the pump efficiency. That is a separate issue.
  • Ammar Aziz
    @ammar-aziz-7MLZYl • Oct 1, 2012
    bioramaniIf you look at the Bernoulli's equation, everything is converted into equivalent height of liquid column. In the present case, the 0.5 m is about 2.5% of the differential head of 20 meters. The implication is that the pump is raising the water not by 20 m but by 20 m + 0.5 m (friction head). In effect the pump consumes proportionately that much more power.
    Thank You Sir
