Project on Fluorescent Light Or Fuse
satty lavanya
satty lavanya
@satty-lavanya-4IoUgk Oct 23, 2024
hi friends.i have an interest to do the project based on the concept of fluorescent light or about fuse ...can u give any idea..........first give me the detail information about fuse....
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Dec 5, 2012
    Awesome info about fuse in <a href="https://en.wikipedia.org/wiki/Fuse_%28electrical%29" target="_blank" rel="nofollow noopener noreferrer">Fuse %28Electrical%29</a> friend do check it up
    And you can try to reduce the ballast voltage need in a FL bulb
    @abrakadabra Dec 5, 2012
    #-Link-Snipped-# You might be interested in this research paper here -
    LIGHTING: A NEW CONCEPT ON RE-UTILIZATION OF
    FUSED FLUORESCENT LAMP
  • satty lavanya
    satty lavanya
    @satty-lavanya-4IoUgk Dec 6, 2012
    Conqueror
    can u tell me in detail.........
  • Jeffrey Arulraj
    Jeffrey Arulraj
    @jeffrey-xA7lUP Dec 6, 2012
    satty lavanya
    About what Little unclear here friend
    Fuse is a protective device which melts when higher current than the rated value flows to the circuit
    About ballast Chokes provide a very high voltage of about 1kV to ionise the gas in the tube there by producing fluorescence in the FL. You can work on alternatives.
    PS: I am not sure if it is possible too so do check online or try the link AKD posted for more info here
  • lal
    lal
    @lal-R60Xjx Dec 7, 2012
    My friend does a crazy thing to light fused Flurescent Lamps 😁 He just short circuits the fused filament with a piece of copper wire at the terminals accessible outside and installs it back. Only to see the light back in operation like a charm 😁
    Well, that is not safe for sure. And that doesn't work if both the filaments are fused. It might come handy though if the situation is urgent.
