@jeffrey-xA7lUP • Mar 3, 2013
Matlab is an efficient signal processing language having its own twists and turns. If you are interested in Java and if you are an expert in progrmming java then learning Matlab is cake walk to you do try it out the experience you gain will be outstanding -
@ginji-CnA5xo • Mar 3, 2013
Ok, thanks a lot. I'l defintly try to learn matlab😀 -
@abhishek-fg9tRh • Mar 3, 2013
I will suggest C/C++.
It's most useful language in Embedded systems. -
i'm now studyng C pgmng.. I like that too. If you know about real life projcts which can b implementd pls do tell. Its that, i would like to know what level of projcts cud b done(any related links).. Again thanks for the info😀 -
I use <a href="https://www.instructables.com" target="_blank" rel="nofollow noopener noreferrer">Yours for the making - Instructables</a> as my guide.ginjii'm now studyng C pgmng.. I like that too. If you know about real life projcts which can b implementd pls do tell. Its that, i would like to know what level of projcts cud b done(any related links).. Again thanks for the info😀
I love DIY projects from it.
But,readymade codes are given alongwith project.
I usually ignore their codes & write mine.That's the way I like.I suggest you to do same.
I am at this moment learning to mess up with Arduino. 😀 -
@anand-tamariya-DnfjEX • Mar 9, 2013
Coming from E&E field, you must learn socket programming in java & C. Also, C is the language of choice for programming microcontrollers (aka the brain behind most of the "intelligent" devices).ginjiHi there. I have learned java & C programming earlier & i've got an interest for that. wanted to know if there is any practical application of this in the electrical & electronics field. How about mat lab? -
@ginji-CnA5xo • Mar 11, 2013
Thank you.. I also prefer to write my own codes😀Troll_So_HardI use <a href="https://www.instructables.com" target="_blank" rel="nofollow noopener noreferrer">Yours for the making - Instructables</a> as my guide.
I went through that. Have to learn that, thank you for the info👍Anand TamariyaComing from E&E field, you must learn socket programming in java & C. Also, C is the language of choice for programming microcontrollers (aka the brain behind most of the "intelligent" devices).
