  • Program to find out Next Palindrome
    sookie
    sookie
    @sookie-T06sFW
    Updated: Oct 23, 2024
    Views: 1.8K
    Hi all programmers here!
    Problem Statement :
    A positive integer is called a palindrome if its representation in the decimal system is the same when read from left to right and from right to left. For a given positive integer K of not more than 1000000 digits, write the value of the smallest palindrome larger than K to output. Numbers are always displayed without leading zeros.
    Input
    The first line contains integer t, the number of test cases. Followed by t lines containing integers K.
    Output
    For each K, output the smallest palindrome larger than K.
    Example
    Input:
    2
    808
    2133
    Output:
    818
    2222
    Warning: large Input/Output data, be careful with certain languages
    Source: <a href="https://www.codechef.com/problems/PALIN" target="_blank" rel="nofollow noopener noreferrer">PALIN Problem | CodeChef</a>
    For above Problem, I created following program and also even submitted at the site mentioned in Source but their machine is again and again giving some Runtime error. As per those folks, it is because I am doing some wrong in I/O handling but as per me , it is working fine in my machine. I am not able to trace it out. 😔 Anyone here any ideas what error could be?
    My Program:
    package code.chef;
    import java.io.BufferedReader;
    import java.io.IOException;
    import java.io.InputStreamReader;
     * @author sookie
    public class NextPalindrome {
       public static void main(String[] args) throws IOException {
            int t, k;
            StringBuilder z;
            BufferedReader bin = new BufferedReader(new InputStreamReader(System.in));
            t = Integer.parseInt(bin.readLine());
            String inputs[] = new String[t];
            for(int i = 0; i < t; i++) {
                inputs[i] = bin.readLine();
            for (int i = 0; i < t; i++) {
                k=Integer.parseInt(inputs[i]);
               do{
                  z=new StringBuilder();
                  k=k+1;
                  z.append(k);
                  z=z.reverse();
                  if(Integer.parseInt(z.toString())==k){
                   System.out.println(k);
                   break;
                 }else continue;
                }while(k>=1);
    Output:
    2
    808
    2222
    818
    2332
    Thanks in advance for finding out at what case, it can give runtime error !
