@ramani-VR4O43 • Sep 3, 2012
Unless you are more specific nobody can comment meaningfully.
1. If you have lot of water at a height you can use it for hydroelectric generation.
2. You can set up a Leclanche cell: <a href="https://en.wikipedia.org/wiki/Leclanch%C3%A9_cell" target="_blank" rel="nofollow noopener noreferrer">Leclanch%C3%A9 Cell</a>
3. You can electrolyse water to produce Hydrogen and Oxygen for later use in a fuel cell. -
@thebigk • Sep 3, 2012
The title of this thread is quite interesting. Actually, it got me thinking whether we can really produce 'electricity inside water'. Is it even possible to produce electricity inside water as a medium? ๐
@vinod1993-r3yTlk • Sep 3, 2012
The_Big_KThe title of this thread is quite interesting. Actually, it got me thinking whether we can really produce 'electricity inside water'. Is it even possible to produce electricity inside water as a medium? ๐
I am not sure but i think it's possible. What if we place "windmill" like turbines underwater? Won't it produce electricity? Any suggestions?
@arunchary-VtqB3c • Sep 5, 2012
electrolysis is one of the commonly used to generation of electricity and also we can observe in general nickel cadmium or lead acid batteries,they may use distilled water to conduct and produce some voltage.water can be used as medium of electricity either phase or neutral not both at a time.example while we performing an experiment on water level control and monitor,reference voltage as to detect by a controller on that time conduction of water is considered.
flowing water can made to generate the electricity by using a wind mill motor to get the pressure of water to rotate and we can get generation of power using this concept. -
@sauravgoswami-UAfTlI • Sep 6, 2012
We cannot use water as a medui inside as it will electrocute life under water, yes, its quit possible to odify the turbine such that it will be driven through water current inside, but it wont work when water is stationery
@ramani-VR4O43 • Sep 6, 2012
Tidal generators are totally immersed. They are reversible and generate both as the tide comes in and goes out.
<a href="https://www.sd-commission.org.uk/pages/tidal-power.html" target="_blank" rel="nofollow noopener noreferrer">Tidal Power ยท I'm interested in ยท Sustainable Development Commission</a> -
@abrakadabra • Sep 6, 2012
ojai21how can i produes electricity in water
You mean - in water or from water or something else? One lined questions don't help. Please elaborate the question.
@jeffrey-xA7lUP • Sep 6, 2012
there is one way that is now used in fuel cells
here water is used that is all i can say
#-Link-Snipped-#: there is a problem more energy is used for rotating the blade under the water than in the air so rather generating there is more loss in it
but i don't think that the blades we use can withstand the water currents at pressures above a ton -
@vinod1993-r3yTlk • Sep 6, 2012
bioramaniTidal generators are totally immersed. They are reversible and generate both as the tide comes in and goes out.
<a href="https://www.sd-commission.org.uk/pages/tidal-power.html" target="_blank" rel="nofollow noopener noreferrer">Tidal Power ยท I'm interested in ยท Sustainable Development Commission</a>Sir,Is there any way to completely rotate the blades? The tidal generator rotation seems more logical but is it possible to make it rotate completely?
@ramani-VR4O43 • Sep 7, 2012
vinod1993Sir,Is there any way to completely rotate the blades? The tidal generator rotation seems more logical but is it possible to make it rotate completely?
There appears to be some miscommunication. Underwater turbines generate much more power than wind mills size for size. This is because for the same velocity the kinetic energy of water is almost three orders of magnitude higher. The animation in the video is only indicative. The actual rotation speeds are much more.
However, there are other issues about tidal power. Here is a different view:
#-Link-Snipped-# -
@sauravgoswami-UAfTlI • Sep 7, 2012
Tidal generators depend upon the flow of tide , if the tide rotates it 360deg it will rotate accordingly,fuel cells are still in early stages of development and i doubt fuel cells can generate MW power.
Sir, the link is very informative, problem mentioned is common to all new technologies introduced,cost can be reduced but major point to figure out is selection of the location, since yeild is very poor or ways to increase the yield say by using trafos or inverters.
bioramaniThere appears to be some miscommunication. Underwater turbines generate much more power than wind mills size for size. This is because for the same velocity the kinetic energy of water is almost three orders of magnitude higher. The animation in the video is only indicative. The actual rotation speeds are much more.
