  • Problems with mouse
    Vivien.hugo
    Member
    Updated: Oct 25, 2024
    I've come across a problem: when I click to swith to another webpage, the page closed. When I click the icon of a website on my browser to open that website, it opened two webpages but I didn't double click that icon! Why do this happen? The mouse is too sensitive?
  • Dancer_Engineer
    MemberApr 2, 2012
    Which browser are you using?
  • PraveenKumar Purushothaman
    MemberApr 6, 2012
    Guess the mouse is too sensitive too... Did you try with another mouse?
  • chiru
    MemberApr 6, 2012
    Your mouse might be the problem, try with other mouse or your OS could have become buggy. Check the sensitivity and scan for virus too.
  • Sahithi Pallavi
    MemberApr 6, 2012
    I've faced the same problem a week back.
    No doubt, Your mouse is the problem. Change your mouse.
    And your present mouse might also be reset after some days. Don't throw it away, keep it with you and give it some days rest 👍
  • Vivien.hugo
    MemberApr 8, 2012
    Hey, guys, thank you all! I'm using sogou explorer and IE explorer. In order to avoid closing the webpage by mistake, I've resetted the broswer: when open multi-webpages, use multi-window mode not multi-tag mode. Although this can't solve the problem from root, but it much better.
  • Vivien.hugo
    MemberApr 8, 2012
    Trying another mouse is a bit trouble since this is the company's computer, I need to apply to change another one and this takes a time.
    If any of above solution doesn't work
    Get a Cat to control your mouse activities. 😲
  • rahul69
    MemberApr 9, 2012
    I think ur left and middle click controls are set on left button. Try changing them from control panel -> mouse properties. Hope it helps.
  • Vivien.hugo
    MemberApr 12, 2012
    rahul69
    I‘ve tried this and it did not work.
  • Vivien.hugo
    MemberApr 12, 2012
    One colleague told me that maybe too much dust get into the mouse. After tried every effort, I finally give up and going to get another mouse.
