Problem with ubuntu install
vivekp26.1
@vivekp261-AOU34p โ€ข Oct 22, 2024
hi
I wanted to install Ubuntu alongside Windows XP.
So I make the partition and do the installation through the CD.
While installing there was a step where we need to create partitions like Root,Boot, swap area. I made it correctly.
There was one more option Select the BootLoader information.
and it automatically taken something I don`t understand it. So I drop down the options and get the list.
I choose the option as Microsoft Windows XP.
and after that I successfully install the ubuntu. Now the problem is whenever I start the laptop I got 4/5 options. Ubuntu generic,memo test etc. Last option is MS Windows XP.
If I want to go for XP its not getting started.
Now what to do?
Ubuntu is working fine. But what to do with XP.
( I am able to access all C drive through Ubuntu. i.e. I have not installed ubuntu at C drive.)
Please help me.
I think I changed the boot loader information.
    @thebigk • Feb 21, 2012
    Getting those 4/5 options is normal and to the best of my knowledge uBuntu adds them by default. You can of course edit those options by going to: System > Administration > StartUp-Manager.
    Could you tell us what exactly happens after you select Windows XP option in the boot loader at the start up? Does the system throw any error message? Typically, if you did not get any error message during the install; the dual boot should work absolutely fine. I've installed uBuntu along with Windows several times and never had a problem.
    Update: I did few searches on Google and found that Canonical has acknowledge few issues with Windows XP, uBuntu dual boot & NTFS. Go through <a href="https://help.ubuntu.com/community/WindowsDualBoot#Issues_with_Windows_XP_and_NTFS" target="_blank" rel="noopener noreferrer">WindowsDualBoot - Community Help Wiki</a> and check if that solves your problem.
    @anoop-kumar-GDGRCn • Feb 23, 2012
    Me too faced this problem and end up to farmating the whole HDD,after that I keep linux on my portable device.
    I recently installed Ubuntu 11.04 on my pen drive and when I need to ubuntu just boot from pen drive.
    Every other thing like all file , drives are usable.
    Ubuntu 11.04 is very good in interface vise .๐Ÿ˜€
  • vivekp26.1
    @vivekp261-AOU34p • Feb 28, 2012
    thank you guys.
    #-Link-Snipped-# : when i select the option MS Windows XP, the screen flashes and again return to the same menu
    Ubuntu generic
    Memory Test
    Memory Test(<something I dnt remember now)
    Microsoft Windows XP Professional
    I think the windows is not getting started as there might be change in Boot Loader information.
    Now what to do to access both the operating systems?
    the final solution is format the C drive install XP first then ubuntu.
    Is there any option like installing XP after Ubuntu?
    i.e. is there any possibility that I can format C drive and install XP but keeping Ubuntu as it is.
    @thebigk • Feb 28, 2012
    Windows usually ignores other operating systems and wipes them out when you're trying to create a dual boot. Even uBuntu asks users to have Windows XP installed first and then go for uBuntu.
    Have you made sure that the media you're installing from is error free? Has it been tested elsewhere? If not, get a fresh copy of uBuntu and burn it on DVD before you proceed.
    I'd also like to have a look at your system configuration & hardware. How are you partitioning the disk for uBuntu (root, swap etc.)?
    @anoop-kumar-GDGRCn • Feb 28, 2012
    If you are deciding again to install xp with ubuntu. use Virtual box.
    <a href="https://www.psychocats.net/ubuntu/virtualbox" target="_blank" rel="nofollow noopener noreferrer">Installing Ubuntu inside Windows using VirtualBox</a>
    to avoid conflict again. In case of problem you can just delete virtual box.
    #-Link-Snipped-# :That's actually a good idea if the hardware is capable. Running two operating systems at a same time is going to hog more resources. That's why asked for system configuration ๐Ÿ˜€
    Minimum 2 GB RAM should run box XP and uBuntu fine. But running them at a same time would require at least 4GB memory.
    Yes,
    hardware limitation is there.
  • vivekp26.1
    @vivekp261-AOU34p • Mar 12, 2012
    thanks you guys for your valuable posts.
    one more thing i want to ask. As I install XP once again in the same laptop( previously it is having ubuntu) the ubuntu is not working as the boot loader information is changed.
    now the problem is in my computer i m not able to see the space allocated for ubuntu. I know as it is linux we can not see the drives of linux in windows.
    my computer is having C, D, E, F drives.
    I want to get the space back as I don`t want to waste the 10GB used by ubuntu(ubuntu is not working), so I go to my computer->manage->disk management
    there i found the space for ubuntu. I selected the space and deleted the ubuntu drives(root,boot and swap).
    But I dnt kno what happend the drives E,F also get deleted.
    as i know they are in NTFS format and only used to store data.
    Now in disk management it is showing free space including the space used by E and F drives.
    My question is what is the reason behind it??
    and how can i restore the space as it is having the important data in it???
    how to recover the data???
    please help me.
    @thebigk • Mar 13, 2012
    It looks like something went wrong when you use the disk management. I don't remember whether the disk management in XP lets you adjust the size of the volume. Your best bet is to try a data recovery software and see whether it can recover your data. I hope you've not formatted your free space; if yes, it's going to complicate the things.
    That's the reason, it's very important to backup the data before you play with hard drives.
    If you have a backup; then simply create new partitions and make sure that uBuntu has about 20-30 GB of space available before you attempt another install.
  • vivekp26.1
    @vivekp261-AOU34p • Mar 13, 2012
    thanks.
    i hav not formatted the disk...also not stored any new data from that incident....
    can you suggest some data recovery softwares....also how to recover data.....
    do i need to remove the hard disk and attach to another machine(where the software is installed) in order to recover that data???..if so is there any software which will recover data in the same machine..means i dnt need to remove the hard drive physically?
  • sunilrk
    @sunilrk-ZCaHW6 • Mar 14, 2012
    If you want to install any linux along side of windows xp.Follow the following procedure
    1. Right click on Mycomputer->manage->Storage->Disk management and delete one extended partition.Dont delete any primary partitions
    2.Now install linux into freespace.Then you will have no problems if you deleted ubuntu again from the diskmanagement
  • Anoop Mathew
    @anoop-FRTf1L • Jul 8, 2012
    I'm also facing a boot problem.
    This is my FIRST attempt at Ubuntu, and I've very little knowledge about it.
    I just installed Ubuntu 12.04 alongside with Windows 7.
    I had downloaded Ubuntu 12.04 and saved it to a DVD after which I installed it.
    I selected the ext4 file system and the mount point as '/'.
    I selected the 20000MB free space from the disk for installing Ubuntu.
    I DID NOT however give a swap space.
    The entire installation is complete and I've removed the DVD.
    But when I restarted my laptop, the boot menu shows only Windows 7 and does not show Ubuntu.
    When I searched the internet, I found out that my MBR (Master Boot Record) must have some wrong settings. But I am not sure how to manually edit the boot and am also unaware of the commands.
    What can I do now?
    P.S. I'm using a Dell Inspiron1525 laptop with 2 GB RAM and 250 GB of HDD.
  • yorha 2b
    @yorha-4BSkiM • Jul 8, 2012
    anoopthefriendI'm also facing a boot problem.
    What can I do now?
    MBR is not my thing , so i do almost everything from partitioning to allocating space manually .. below are the steps ..
    1) Install windows 7 (with minimum 4 drives .. C drive(8 to 10 gb) in which Win7 is allocated ... D (ur data) .. E (ur data)...F (empty) ... well we are installing ubuntu in last drive so i said F empty .. by the way you can keep D or E empty too)
    2) Insert ubuntu disk
    3) Once installation starts it will ask i) Install Linux alongwith Windows ii) Replace Windows with Linux iii)Something else
    4) Click "something else" & press forward button
    5) After that you will see hard disk partition. I installed ubuntu in my Fourth partition (Disk0 Partition4)
    6) First press "add" button .. you will see create partition box in that go to mount point place ... select /boot give 2000MB (depends upon your drive space availability) .. same as do for /home 2000MB, /tem 2000MB, /user 8000MB (More the user space it will be better), /var 2000MB, /srv 2000MB, /opt 2000MB & /usr/local 2000MB.
    Now very important step
    7)How to give "SWAP AREA" ...For that go in "Use as" - place by default you will see "Ext4 journaling file system" ... press on "down mark" you will see 11th option & from bottom 2nd option "SWAP AREA" .. just press on it.
    Give 2 times your RAM size .... I have 4 GB ,so I gave 8192MB to "SWAP AREA".
    8)After giving SWAP AREA ... allocate remaining space to "/"(This is called root).
    9) Press "Install Now" button.
    After full installation .. reboot & you will see GRUB with ubuntu, ubuntu recovery mode, Windows 7...
    Enjoy ๐Ÿ˜€
  • Reya
    @reya-SMihdC • Jul 8, 2012
    Did you check that ubuntu is installed using windows live cd?
  • yorha 2b
    ReyaDid you check that ubuntu is installed using windows live cd?
    The only mistake #-Link-Snipped-# did is by not allocating SWAP AREA. He was just too close to success ๐Ÿ˜’
  • Anoop Mathew
    BetterThanBeforeMBR is not my thing , so i do almost everything from partitioning to allocating space manually .. below are the steps ..
    Enjoy ๐Ÿ˜€
    Thanks! It works ๐Ÿ˜€
  • Anoop Mathew
    @anoop-FRTf1L • Jul 28, 2013
    Need this again so bumping this thread. ๐Ÿ˜€
    @abhishek-fg9tRh • Jul 28, 2013
    anoopthefriendNeed this again so bumping this thread. ๐Ÿ˜€
    #-Link-Snipped-# <a href="https://www.crazyengineers.com/threads/how-to-dual-boot-windows-any-linux-os-with-pictures.68847">How To Dual-Boot Windows & Any Linux OS (With Pictures).</a>
  • Anoop Mathew
    @anoop-FRTf1L • Jul 29, 2013
    Abhishek Rawal#-Link-Snipped-# <a href="https://www.crazyengineers.com/threads/how-to-dual-boot-windows-any-linux-os-with-pictures.68847">How To Dual-Boot Windows & Any Linux OS (With Pictures).</a>
    I've got a different issue now. I've a Ubuntu 12.04 Desktop version ( 32 bit ) and earlier it was working well in my Dell Inspiron 1525 laptop. But once I've changed my laptop to Sony Vaio SCE14A15 model, I'm have this problem of dual booting along side Windows.
    There are 2 options for booting in Sony Vaio -
    1. UEFI Mode and
    2. Legacy Mode,
    and I've checked the net for some answers.
    Apparently, my Windows 7 (Home Premium) loads using UEFI boot mode, and Ubuntu (i guess) loads from Legacy Mode. This I understand is due to a fact called as Secure Booting (I'm unaware of further details).
    How should I deal with this situation? #-Link-Snipped-# they have mentioned many options, but I'm a bit confused whether I should just stick to plain old Virtual Box or do a dual boot.
    Update: Looks like 64 bit could do the trick, but first I've got to download the latest Ubuntu version.
  • pradeep.pawar
    @pradeeppawar-RAMDdD • Aug 5, 2013
    <a href="https://neosmart.net/EasyBCD/" target="_blank" rel="nofollow noopener noreferrer">EasyBCD - NeoSmart Technologies</a>
    Use the above software
    Always keeps bootloader for ubuntu, I have windows 8 and bootloader set to ubuntu, only problem here is if bootloader for ubuntu fails then its shows grub rescue message and windows also doesn't boots up at that time i use windows 8 dvd, run in advanced option, cmd type bootrec/fixboot and fixmbr, it boots windows 8 and then again install ubuntu.
    Here you may have to boot from windows xp cd and try repairing the windows installation , press r and type chkdsk/r.
  • pradeep.pawar
    <a href="https://en.wikipedia.org/wiki/GNU_GRUB" target="_blank" rel="nofollow noopener noreferrer">Gnu Grub</a>
    Check the source
