Problem with PC
Yamini L
@yamini-uMEVDQ โ€ข Oct 26, 2024
Hi friends,
I too have a problem with my PC..Sometimes when i'm working my PC suddenly gets off(shutting down)on its own..I was advised to format my system..I would like to know the actual cause behind this..Just do help me out....
    @thebigk • Apr 12, 2008
    Well, I believe it would be difficult to answer without knowing the OS. ๐Ÿ˜€
    I have never noticed such problem with Mac.
  • Ashraf HZ
    @Ash • Apr 12, 2008
    Miniy, did any error message or pop up saying it was about to shutdown?
    @thebigk • Apr 13, 2008
    Actually, the situation normally happens when you've automatic updates enabled. Once the update is installed, Windows normally needs a restart.
  • Ashraf HZ
    @Ash • Apr 13, 2008
    The_Big_KActually, the situation normally happens when you've automatic updates enabled. Once the update is installed, Windows normally needs a restart.
    It does, but there is usually a message that asks whether to restart now or later ๐Ÿ˜› I'd be kinda pissed if the updates restart my computer without my permission.
    ashIt does, but there is usually a message that asks whether to restart now or later ๐Ÿ˜› I'd be kinda pissed if the updates restart my computer without my permission.
    Yeh, and it always shows "Shutting down in 4 minutes" ๐Ÿ˜ก . Especially when I'm streaming Dilbert Cartoons on YouTube ๐Ÿ˜‰.
  • Ashraf HZ
    @Ash • Apr 13, 2008
    Oh, I didnt realise there is a countdown timer. Perhaps thats a feature of Vista only? ๐Ÿ˜›
    Ya know, I didnt know there were dilbert cartoons ๐Ÿ˜› I've only ever read the comics! Damn, I'm going to be super addicted to watching it now.
  • Ashraf HZ
    @Ash • Apr 13, 2008
    Biggie, wants the most efficient way to stream the dilbert clips? ๐Ÿ˜€
    This one is so damn funny! -> <a href="https://www.youtube.com/watch?v=qOtoujYOWw0" target="_blank" rel="nofollow noopener noreferrer">- YouTube</a>
    Check it out CEans!
    [EDIT]
    And this! <a href="https://www.youtube.com/watch?v=lXGDRrkaRgU" target="_blank" rel="nofollow noopener noreferrer">Engineer - YouTube</a>
    Sorry Miniy for hijacking your thread ๐Ÿ˜› We'll be waiting for your response, though. Please list out what OS you use as well as your computer specifications just in case.
  • Yamini L
    @yamini-uMEVDQ • Apr 13, 2008
    No messages popped off....Suddenly system gets off on its own(i couldn't shut it down too).....
    miniyNo messages popped off....Suddenly system gets off on its own(i couldn't shut it down too).....
    Okay, we'll now try to guess the OS on your system.
    Windows XP (SP2) - I say. What do you say, ash? ๐Ÿ˜
  • engineer_vinay
    @engineer-vinay-vETp5V • Apr 13, 2008
    may be this a hardware issue, like on-off switch, keyboard. Check your keyboard's key and on/off switch also.
  • friendster7
    @friendster7-oVJr9h • Apr 13, 2008
    Sounds like a fault either in the hardware - faulty motherboard
    or overheating - a fan has blown somewhere...
    How long does it run before switching off? Is it the same length of time each time?
    I had a system switch off repeatedly after 20 minutes. Turns out a PSU fan had blown and the heat in the case had no where to go.
    I replaced the fan, no bother now.
    • 7 months ago
    Source(s):
    Try this as well.
    Click on START. Right-Click on My Computer and select Properties.
    In the System Properties window, select the ADVANCED tab.
    On the Advanced window, uncheck the box marked "Automatic Restart".
    Now when your computer goes to close down, it may produce a BSOD (Blue Screen of Death) with information in white letters about possible causes.
    Make a note of the numbers and Google for them. You may find there's a fault that is easily tackled.
  • rohit007
    @rohit007-Vf88xJ • Apr 18, 2008
    only one solution of this problem is................................format your pc.
  • rohit007
    my pc has been infected with virus named funny.avi
  • robby
    @robby-WQiGQU • Apr 21, 2008
    my keyboard not working properly , wht to do?it stop working in between....
  • arunbasillal
    @arunbasillal-7szUxa • Jul 5, 2008
    Hey, I think its a Virus. Do you have any other problem, like is your Windows task manger disabled.. or is the system excessively slow..?
