I am using a 60Hz EEG Acquisition device which was imported from the US. I am an Indian and the AC power frequency here is 50Hz. The device is called Neurosky Mindwave. Its connected to the laptop through bluetooth connectivity. The bluetooth connectivity remains only for sometime. Please let me know what the problem is? The laptop used in India can also be used in US right? Or else is there any problem with 50 Hz and 60Hz power freq.? Does this have anything to do with wireless connection?0
Member • Jul 11, 2013
Yup pls don't try to use 60 Hz product in 50 Hz AC supply unless u use a frequency shifterAre you sure? This action cannot be undone. -
But does it effect wireless signals sent via bluetooth? Please let me know how i can use a frequency shifter for bluetooth connectivity.Are you sure? This action cannot be undone. -
Just make sure you supply power properly. The device which is working on 60hz.. does it have any power adaptor?PriyaJBut does it effect wireless signals sent via bluetooth? Please let me know how i can use a frequency shifter for bluetooth connectivity.
Please check what's input frequency written on it?Are you sure? This action cannot be undone. -
Its powered through a AAA battery. The bluetooth connectivity is just to acquire the EEG signals.Are you sure? This action cannot be undone. -
Now I am confused. You said your device is working on 60hz but if it is powered by AAA battery it means its DC supply. No worry about it if power source is DC. Is your device using any AC source?PriyaJIts powered through a AAA battery. The bluetooth connectivity is just to acquire the EEG signals.Are you sure? This action cannot be undone. -
No its connected to a laptop thats using AC source. We are sending signals from the device(which is powered with battery) to a laptop(which is powered using AC) via bluetooth. But the connectivity is not maintained for a long time.Are you sure? This action cannot be undone. -
No. We are sending signals from the device(which is powered with battery) to a laptop(which is powered using AC) via bluetooth. But the connectivity is not maintained for a long time. I wanted to know if bluetooth signals have anything to do with that 50Hz and 60Hz.Are you sure? This action cannot be undone. -
So what I understand is device you import from USA is battery powered and Bluetooth enabled. While another Bluetooth device is the one in your laptop which is Indian model right?PriyaJNo. We are sending signals from the device(which is powered with battery) to a laptop(which is powered using AC) via bluetooth. But the connectivity is not maintained for a long time. I wanted to know if bluetooth signals have anything to do with that 50Hz and 60Hz.
Then I'm sure there is no any impact on Bluetooth signal as Bluetooth is working on DC power only. There must be some other issues.Are you sure? This action cannot be undone. -
Try to reset both Bluetooth devices and make sure you are configuring Bluetooth as per the manual.
You just have to worry about 60hz and 50hz if your input is AC source.Are you sure? This action cannot be undone. -
Ya you are right. Its an Indian Model only. Thanks a lot!! I'll check out what other problem can be there. Thank You.Are you sure? This action cannot be undone. -
K. Fine. I'll do that.Are you sure? This action cannot be undone. -
Great !PriyaJK. Fine. I'll do that.
Don't forgot to update this thread once you find the solution or you have any other doubt so that will be useful to others too.
Have a nice time on CE.Are you sure? This action cannot be undone.
