Problem: "Task manager disabled by administrator" in Windows XP SP2
prabhat kumar
@prabhat-kumar-KhhWSv • Oct 26, 2024
hi!!!!! Every one i have the problem in open the task manager,i m using winXpSp2,when i press alt+ctrl+delete,then i see the msg "task manager disable by your administrator,i m the administrator
please help me!!!!!!!!
  • silverscorpion
    @silverscorpion-iJKtdQ • Jan 28, 2009
    Re: problem on Task manager
    It's most probably a virus attack. Use a good anti virus software and clean up your pc first. Then if the problem still persists, let us know.
    @thebigk • Jan 28, 2009
    Try this -
    Click Start
    Click Run
    Enter gpedit.msc in the Open box and click OK
    In the Group Policy settings window
    Select User Configuration
    Select Administrative Templates
    Select System
    Select Ctrl+Alt+Delete options
    Select Remove Task Manager
    Double-click the Remove Task Manager option
  • prabhat kumar
    @prabhat-kumar-KhhWSv • Jan 29, 2009
    Thank you Big_k !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!it's working
  • Riyan587
    @riyan587-zi2E1d • Dec 10, 2010
    Hi
    Task manager is an application which provides detailed information about the various applications and processes which are running and how they are responding. So it is very useful element in a computer. As per the query if you are getting the error “Task manager disabled by administrator” you need to do the steps #-Link-Snipped-#
    Hope it will work for you…
    Good Luck
