Problem In Nerwork [socket connection]
madhumurundi
@madhumurundi-DfePI4 โ€ข Oct 21, 2024
hi, friends getting some problem in socket connection b\w two systems.....progrmme is running in a standalone..but not in across the network.....in our project we are using...socket programming for communication and port address as:6789... ..eventhough LAN is good but socket is not creating b\w two systems .....how to solve this problem....๐Ÿ˜•๐Ÿ˜•
plz any body....help me...........๐Ÿ˜”๐Ÿ˜”๐Ÿ˜”
  • mahul
    @mahul-ZxpiLA • May 13, 2008
    Re: Problem In Nerwork
    try a huge port address value, something like 13000 or 16000. Do inform us if that solves your problem.
  • Ashraf HZ
    @Ash • May 14, 2008
    Oh, thats the first time I came across "socket programming"!
    Is it like this? #-Link-Snipped-#
    Anyhow, if you are directly connecting between two computers using network cards, you must use a crossover cable. Its a modified cat5e cable allowing for peer-to-peer network connections. Useful stuff for 1 on 1 LAN gaming if you don't want to use wireless ๐Ÿ˜‰
    Of course, if you are using a hub, then just ignore whatever I said above ๐Ÿ˜›
  • just2rock
    @just2rock-DkmPtO • May 25, 2008
    for Power over Ethernet and long Haul communication,Cat6 cable will be best
  • koli
    @koli-QCL7Nj • Jun 26, 2008
    telenet to the socket and check from local host
    e.g. for socket 6060
    telnet 10.10.10.10:6060
    if it holds the connection on the server / destination socket then there could be possibility of issue with client / destination.
