@pradeep-agrawal-rhdX5z • Mar 16, 2008
sahanai have to multiply 2 n*m matrices using pointers
When you say pointers, do you meant that the matrices are implemented using linked list? Could you please provide more details on how the matrices are implemented.
-Pradeep -
sahana OP
@sahana-S4nL10 • Mar 17, 2008
yeah u can implement it by a linked list.
@friendster7-oVJr9h • Mar 17, 2008
if u need to multiply then check out this..this might help
#include<stdio.h> #include<conio.h> main() { int mtrx1[5][5],mtrx2[5][5],product[5][5],ro1,ro2,col1,col2; unsigned short int posblty; static unsigned short int call_main = 0; if(call_main == 0 || call_main % 10 == 0) { clrscr(); printf("\nThis program will calculate the product of two matrices"); printf("\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~"); } call_main++; getnum(&ro1,1); getnum(&col1,3); getnum(&ro2,2); getnum(&col2,4); posblty = is_posble(col1,ro2); if(!posblty) { getch(); repeat(); } getmatrix(mtrx1,ro1,col1,1); getmatrix(mtrx2,ro2,col2,2); multiply(mtrx1,mtrx2,product,ro1,col2,col1); print_matrix(product,ro1,col2); find_trace(product,ro1,col2); repeat(); } getnum(num,message) int *num,message; { do { switch(message) { case 1: printf("\nEnter the number of rows in matrix 1:"); break; case 2: printf("\nEnter the number of rows in matrix 2:"); break; case 3: printf("\nEnter the number of columns in matrix 1:"); break; case 4: printf("\nEnter the number of columns in matrix 2:"); break; default: printf("\nEnter a number:"); } scanf("%d",num); } while(*num > 5); return; } is_posble(col_1,row_2) int row_2,col_1; { if(col_1 != row_2) { printf("\nThe multiplication of given matrices is not possible"); return(0); } else { return(1); } } getmatrix(array,row,column,mtrx_num) int *array[5],row,column,mtrx_num; { int i,j; printf("\nEnter matrix %d\n",mtrx_num); for(i = 0;i < row;i++) { for(j = 0;j < column;j++) { scanf("%d",array+(5*i+j)); } } return; } multiply(matrix1,matrix2,product,l,m,n) int *matrix1[5],*matrix2[5],*product[5],l,m,n; { int i,j,k,temp1,temp2,temp3; for(i=0;i < l;i++) { for(j = 0;j < m;j++) { *(product+(5*i+j)) = 0; for(k = 0;k < n;k++) { temp1 = *(matrix1+(5*i+k)); temp2 = *(matrix2+(5*k+j)); temp3 = *(product+(5*i+j)); *(product+(5*i+j)) = temp1 * temp2 + temp3; } } } return; } print_matrix(array,row,col) int *array[5]; { int i,j; printf("\nThe product is :"); for(i = 0;i < row;i++) { printf("\n"); for(j = 0;j < col;j++) { printf("%5d \t",*(array+(5*i+j))); } } return; } -
sahana OP
@sahana-S4nL10 • Mar 18, 2008
hi friendster7,
i got your code.but is the most optimal?this code is designed for matrices which have a maximum of 5 rows and 5 columns right?so if i dont use a 5*5 matrix (say 3*3 ), its going to be a waste of space right?can we make it a little more optimal.how about dyanamic memory allocation?
please tell me if i have undserstood it wrongly.
another constraint i forgot to add in the question is that we cannot get the size of the matrix during runtime and then assign the subscript of the array.
ie something like
scanf("%d,%d",&rows,&col);
int array[row][col];
otherwise your code was really good.
