Problem Concerning C Lang
sam_from_hell
@sam-from-hell-8gE2gC β€’ Oct 22, 2024
Hello s
I started learning C programming a month or two ago.
I tried to use the clrscr(); fuction in the program
i have included conio.n and stdio.h , but the compiler i use throws up "Undefined reference to clrscr()" error while compiling. Anyone know why? I googled ( as i usually do when i meet with a problem) but nothing..
I am using the latest version of Code::Blocks
- Thanks Sam 😁
  • Manish Goyal
    @manish-r2Hoep Sep 25, 2010
    it is conio.h not conio.n
  • sam_from_hell
    @sam-from-hell-8gE2gC Sep 25, 2010
    sorry typo
    *i included conio.h 😁
  • Manish Goyal
    can you post your program and which compiler are you using?
  • sam_from_hell
    This is a small program i learnt to compare two strings using strcmp()..
    I use CodeBlocks, and the GNU GCC compiler.
    #include<stdio.h>
    #include<conio.h>
    #include<string.h>
    int main (void)
         char password[11]= {"qwerty"};
         char inputpassword[11]= "";
         char newpassword[11]="";
         char response[2]="";
         char responsey[2]="Y";
         char responsen[2]="N";
         int i=0;
         while (i<10)
             printf("Enter Password :\n");
             gets(inputpassword);
             if (strcmp(password,inputpassword)==0)
                   printf("Do u want to change password?[Y/N]:\n");
                   scanf("%s",response);
                   if (strcmpi(responsey,response)==0)
                          printf("Enter new password:\n");
                          scanf("%s", password);
                          printf("The new password is: %s\n", password);
                   else
                          printf("Welcome:\n");
             else
                   //clrscr();
                   printf("Invalid Password\n");
             i++;
         getch();
  • anandkumarjha
    @anandkumarjha-jzdDMA Sep 25, 2010
    #include<stdio.h>
    #include<conio.h>
    #include<string.h>
    int main (void)
    int i=0;
    while (i<10)
    if (strcmp(responsey,response)==0)
    else
    else
    //clrscr();
    i++;
    getch();
    Try this code
  • Manish Goyal
    if you using gnu gcc compiler then conio.h will not work
    and also you have to include file as
    include<stdio>
  • sam_from_hell
    goyal420if you using gnu gcc compiler then conio.h will not work
    include<stdio>
    ok thanks, i will check it out 😁
  • sam_from_hell
    @sam-from-hell-8gE2gC Sep 27, 2010
    include<stdio>
    GNU GCC does support conio.h..
    the solution for the problem i originally posted is to use a user defined function that can be found here instead of clrscr(); ( u can create a header file from the code given in the end of the link)
    https://faq.cprogramming.com/cgi-bin/smartfaq.cgi?answer=1031963460&id=1043284385
    (found this after asking 3 people lol 😁 )
    also you cant use "include <stdio>" for some reason(maybe because i'm using c and not c++)
    it HAS to be #inlcude<stdio.h>
    --Thanks Sam 😁
