@freak16-XgiLj6 • Apr 13, 2011
Is numerical relay a digital relay? What is it? what is its purpose?
vibhor_one OP
@vibhor-one-zP13jP • Apr 13, 2011
No, numerical relay cannot be certainly digital. Here, I mean that it is based on microprocessor technology. It is basically a type of relay and serves in various purpose in power system protection.
@praveenkumar-66Ze92 • Apr 14, 2011
It is just for protection of the equipment from dangerous power by using a microcontroller, checking for the input power... Hey, it is digital, why Vibhor, you said it as not digital???
@vikeshrajan-OWBU0k • Apr 14, 2011
@Praveen:Give brief detail
The numeric relay or digital protective relay, is a protective relay used in Electrical and Electronic circuits. It has a microprocessor with software installed to analyse the voltages for detecting the faults in the power systems. Best use can be found in your day to day stuffs like SMPS in computer.
vibhor_one OP
@vibhor-one-zP13jP • Apr 15, 2011
praveen you said correct, but I am confused with power being given to numerical relay is ac or dc. Is there any conversion ac to dc? If it is so, then what is the reason for this conversion...I hope that you can understand my question now...
@praveenkumar-66Ze92 • Apr 15, 2011
vibhor_onepraveen you said correct, but I am confused with power being given to numerical relay is ac or dc. Is there any conversion ac to dc? If it is so, then what is the reason for this conversion...I hope that you can understand my question now...
Hey, analog-to-digital conversion will take place. This is because, the microcontroller understands only digital input and the AC would be converted into DC and analysed. It is done by a set of rectifiers. Hope this answers your question... ๐
@frodorok-KGYXm6 • Apr 15, 2011
there are plenty of numerical relays available in market.
every one of them is different in there mechanism and purpose so it will be vague to answere this question unless one knows the make, type, sl no etc of the numerical relay.
numerical relays can be fed with ac.
normaly there are 3 or 4 elements for sensing of fault is used in this relays.
the supply it can get from current transformers(class p).
for lv it can be directly coupled. -
vibhor_one OP
@vibhor-one-zP13jP • Apr 17, 2011
thanks for replying, I have got my answer. Thanks Praveen and frodo.rok...
@praveenkumar-66Ze92 • Apr 18, 2011
vibhor_onethanks for replying, I have got my answer. Thanks Praveen and frodo.rok...
Pleasure is ours... By the way, are you working on something which uses relays??? Mind sharing it here???
vibhor_one OP
@vibhor-one-zP13jP • Apr 24, 2011
no just studying the technolgy...
@praveenkumar-66Ze92 • Apr 24, 2011
