PMDC motor and other electrical machines.
zaveri
@zaveri-5TD6Sk Oct 26, 2024
1. Permanent magnet DC motors have a permanent magnet as the field magnet. According to laws of physics, a permanent magnet loses its magnetic property if subjected to heat. now when this PMDC motor is made to work for a long time, then doesn't the field magnet lose the magnetism ?
2. Is there any such thing as Permanent magnet DC generators and alternators ?
3. In case of an automobile alternator, the field coil receives current for excitation, from some external power source such as the battery. how is it in the case of alternators used in power plants and the engine powered generators used domestically ?
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU Jan 2, 2014
    zaveri1. Permanent magnet DC motors have a permanent magnet as the field magnet. According to laws of physics, a permanent magnet loses its magnetic property if subjected to heat. now when this PMDC motor is made to work for a long time, then doesn't the field magnet lose the magnetism ?
    magnets loose their property when subjected to high temparatures but in pmdcs the may not reach to that particular temparature so the magnet may not loose its magnetism
    in automobiles maximum pmdc are used and in alternators that were used in power plants the excitation is given from the batteries or from other sources i.e ac/dc coversion
    in domestic generators due to residual magnitism some emf is induced so that voltage is developed automatically
  • zaveri
    @zaveri-5TD6Sk Jan 10, 2014
    @#-Link-Snipped-#
    what do you have to say to this buddy ?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jan 11, 2014
    Sorry Zaveri I think @#-Link-Snipped-# is well versed in this area than me.
    My two cents
    Magnet looses magnetism only on heating beyond curie temperature, PMDC motors can't generate that much current on their own. PMDC can self cool itself even while running due to heat radiated outside from them
    PM motors and generators are rarely used <a href="https://www.hydrogenappliances.com/powerpmas.html" target="_blank" rel="nofollow noopener noreferrer">Supercore PMA powercore pma ultracore pmg super core dual core Wind generators and turbines from home power and sustainable energy</a> Check the link it gives a little about the area where they are helpful
    In seperately excited DC generator the field coil is fed from a power source externally. But in the case of the Self excited DC generator the part of generated voltage is used for excitation of field coil
  • lal
    lal
    @lal-R60Xjx Jan 11, 2014
    1. All motors are designed to deliver a rated power output (in fact designed to deliver a little higher power than the rated value). The current that would be used to deliver this power would generate heat only in the safe limits. Unless the motor is oveloaded for long intervals or forcefully driven at higher power or some fault occurs, the temperature wouldn't rise much. Thus, the permanent magnets in the motor will not lose its magnetism due to temperature rise if the motor is used the way it is designed to.
    But, since the magnets are dealing with magnetic stress and strain generated by the armature and a magnet is not expected to retain the same magnetism forever, it would eventually deteriorate some day.
    2. Yes, my cycle dynamo was one such alternator.
    3. In large machines, sometimes a small DC generator is coupled to the same shaft as the large alternator to power its field. For dc generators, as Jeffrey said, self excited field is powered from the output of the generator itself and some kind of external power source is used for seperately excited type.
  • zaveri
    @zaveri-5TD6Sk Jan 12, 2014
    @#-Link-Snipped-# @#-Link-Snipped-#
    Thanx a loT guys
    @sarathkumar-FEGRPw Jan 12, 2014
    thanks to @#-Link-Snipped-# , @#-Link-Snipped-# , @#-Link-Snipped-# for this insight view on PMDC.
