plzzzz help: Computer asks to choose a program while opening a drive
crazytechie
@crazytechie-OcNbIK Oct 26, 2024
every time i try openin any of da drives...im askd 2 choose a program to open it with!!..im not able 2 xplore also....
  • friendster7
    @friendster7-oVJr9h Feb 27, 2008
    Re: plzzzz help
    ur system might be infected with virus..i guess..try installing Xp once again..
  • night crawler
    @night-crawler-b6rNvm Feb 27, 2008
    Re: plzzzz help
    format ur comp. & reinstall the operating system
    @thebigk Feb 27, 2008
    Re: plzzzz help
    Good to see your responses, friends. Please avoid using sms text while posting on CE Forums. Go through Quick Start Guide (Link in my signature) and 'About CE' on our front page at <a href="https://www.crazyengineers.com">CrazyEngineers</a>
  • mahul
    @mahul-ZxpiLA Feb 27, 2008
    just restore your system to an earlier date when everything was well and fine. and if this did not happen because u fiddled a little with ur system, it is probably because of some virus, so it will recur(assuming everything turns out fine after u restore), try cleaning it up with some good antivirus. do keep us posted.
  • MaRo
    @maro-Ce3knx Feb 27, 2008
    OK, I don't think Reinstalling or formatting is a good Idea.
    There is a small program can remove it all, but i don't have it right now
    Don't REINSTALL or FORMAT just wait, I'll get it here.
  • soul_hacker
    @soul-hacker-QZaoNw Apr 9, 2008
    Well this problem is mainly due to your Autorun.inf file may have got currupted or virus.
    To access ur drive go to run and type the drive lettrer. You will be able to open the drive.
    Try copying the autorun.inf from other pc to ur pc.
    Other wise u can create it urself..Refer to web.
  • arunbasillal
    @arunbasillal-7szUxa Jul 6, 2008
    No, This is not Virus. Just right click on the drive and select open. Then type in the address bar Autorun.inf so that the address reads C:\Autorun.inf replacing C by the letter of the infected Drive. If that file opens you have found your problem.
    To remove this take command prompt ( Start menu >> Run >> Type cmd and press enter ). I hope this problem is not in your C drive. Let it be in D drive. So type D: and press enter in the command prompt.
    Now your address in the command prompt will read D:\>.
    Type ' del autorun.inf ' without quotes and press enter.
    If the problem still persists, just tell me..ok
