  • please urgent, How to design front end for INTEGER FACTORIZATION TOOL?
    Updated: Oct 26, 2024
    Views: 1.1K
    Hi every one,
    My project is Design and Implementation of Integer Factorization Tool based on Multiple Algorithms.I have written code using trial division method, pollards factorization methods ,ecm,quadratic sieve algorithms.I used only two text boxes, one is for input and one is for output,one command to run the back end program on the front end. I used Net Beans IDE for my project.
    can we called this is a tool?
    My friends are saying that this is not a tool?
    If not , can suggest me how to develop tool?
  • mohammadfawaz
    MemberJul 7, 2010
    If that's what's required, then that's the tool needed. You have designed a program that has an input and has an output. I don't think more is needed. That's you tool.
  • silverscorpion
    MemberJul 8, 2010
    You can also include options for selecting the algorithm to be used for factorization.
    Use some radio buttons and get the desired algorithm as input. Then use those two text boxes as input and output.
    May be it'll be better.
    And whether you include this or not, still, this can certainly be called as a tool..
