  • Nayan Goenka
    @nayan-Dhpt4N • Aug 11, 2013
    It depends on the type of plastic you are using. Brittle plastic would shatter when concrete begins to dry. Hard plastic may not shatter but it will not stick perfectly to concrete. This is my perception. I may be wrong.
  • Saiwal
    @saiwal-NOzuWb • Aug 11, 2013
    Rajcivldoes plastic and concrete bonds together??
    are you referring to surface to surface interaction between plastic and concrete or bonding between plastic fibers in concrete ?
  • Rajcivl
    Rajcivl OP
    @rajcivl-63stXD • Aug 16, 2013
    what i want is to replace plastic in case of steel and to bond plastic and concrete together. whether it can be made? is it effective to do??
  • Nayan Goenka
    @nayan-Dhpt4N • Aug 16, 2013
    Rajcivlwhat i want is to replace plastic in case of steel and to bond plastic and concrete together. whether it can be made? is it effective to do??
    you will not be getting the strength from plastic as needed the quality we get from steel.
  • Rajcivl
    Rajcivl OP
    but incase of members which doesnot need highstrength and all can we use that plastic is that a cost effective one when compared to steel??
    Nayan Goenkayou will not be getting the strength from plastic as needed the quality we get from steel.
  • Saiwal
    @saiwal-NOzuWb • Aug 16, 2013
    Rajcivlbut incase of members which doesnot need highstrength and all can we use that plastic is that a cost effective one when compared to steel??
    you might have to conduct experiments to know the bonding properties between a plastic rebar and concrete. A pullout test is usually apt in this case.
  • Nayan Goenka
    You may make an item with plastic as a substitute. But think of durability. comparitively, if steel costs 50₹, it will last 100years whereas plastic will cost 2Rs but will last only 5 years. So total cost in long run is more. Even if your item doesn't need strength,it should be cost effective as well as feasible. To replace steel, you will have to get your plastic tailor-made.
  • rithesh salian
    @rithesh-xuxaQi • Aug 28, 2013
    Fibre Reinforced plastic and glass reinforced concrete
    @ramani-VR4O43 • Aug 29, 2013
    <a href="https://www.academia.edu/235052/Using_Fibers_in_the_Reinforcement_of_Concrete" target="_blank" rel="nofollow noopener noreferrer">(DOC) Using Fibers in the Reinforcement of Concrete | Sahar El Marsafy - Academia.edu</a>
  • Rajcivl
    Rajcivl OP
    @rajcivl-63stXD • Sep 3, 2013
    A.V.Ramani<a href="https://www.academia.edu/235052/Using_Fibers_in_the_Reinforcement_of_Concrete" target="_blank" rel="nofollow noopener noreferrer">(DOC) Using Fibers in the Reinforcement of Concrete | Sahar El Marsafy - Academia.edu</a>
    sir only one thing i cant understand is steel completely replaced by fiber there are fiber is just mixed with concrete?
    @ramani-VR4O43 • Sep 3, 2013
    Rajcivlsir only one thing i cant understand is steel completely replaced by fiber there are fiber is just mixed with concrete?
    In the paper referred, no steel has been used. Please refer to item 3.2. Techniques in the paper.
