@yogibharadwaj-l2QJTU • Oct 2, 2013
can u tell me the project aim.what u wants to do?
SurEC93 OP
@surec93-HQMaVg • Oct 2, 2013
This is the receiver unit that will receive information through rf module and send it through GSM. Also the location will be sent by getting it through GPS receiver.
connections are right because pic16f uses pin 25-26 for wireless communication what error it shows?
@harshad-ukH5ww • Oct 2, 2013
Will you please explain me why you want RS485 interface between PIC and GSM modem?
For RS485 communication you will need to change one pin HIGH and LOW based on the transmission or reception if you are using RS485 chip with SIM300 GSM modem how your modem is going to control this pin? Modem is not capable for that.
Are you not going to use all these things PIC,GSM,GPS and RF on single board? -
SurEC93 OP
@surec93-HQMaVg • Oct 16, 2013
Harshad ItaliyaWill you please explain me why you want RS485 interface between PIC and GSM modem?
Are you not going to use all these things PIC,GSM,GPS and RF on single board?Actually even I don't know the exact use of RS485 and its working. Would you please try and explain a bit about it?
@harshad-ukH5ww • May 1, 2023
SurEC93Actually even I don't know the exact use of RS485 and its working. Would you please try and explain a bit about it?
Normally RS485 is used to replace your UART communication for long distance.
UART have limitation that it can not go beyond some distance and if you replace it with RS485 you can achieve higher communication distance with same UART protocol.
Have a look at this link :- #-Link-Snipped-#
