PIC 16F876A hex file
EngrJidiqBhai
@engrjidiqbhai-8yfhLZ โ€ข Oct 21, 2024
I have a project on PIC16F876A micro controller, I have the complete coding in .txt and .c files and I want the .hex file for it.
I have tried MPLab and PCW and I get some errors in compilation so can anyone help me in this regard.
I am attaching the the .txt file of the coding and if some one can create the .hex for me I will be very thankful..
Thanks...
    @harshad-ukH5ww • May 11, 2012
    Can you post the screenshot of the error while you are compiling the code.
  • EngrJidiqBhai
    @engrjidiqbhai-8yfhLZ • May 12, 2012
    ok
    Here is the screenshot of the errors that I am getting,,,
    @harshad-ukH5ww • May 13, 2012
    EngrJidiqBhaiok
    There is some issue with your Header and include files. I haven't used MiKroC but I will give it a try into MPLAB and if possible will compile same code in MikroC also.
    @harshad-ukH5ww • May 15, 2012
    All these errors and warning are related DIRECTIVES you have used. Do you have written this code by yourself or copied from any source?
    Seems the code written is not for MikroC compiler as Directives you had used are not allowed in MikroC.
  • EngrJidiqBhai
    @engrjidiqbhai-8yfhLZ • May 16, 2012
    godfatherAll these errors and warning are related DIRECTIVES you have used. Do you have written this code by yourself or copied from any source?
    Its copied from internet...
    Now what to do ???
    @harshad-ukH5ww • May 16, 2012
    EngrJidiqBhaiIts copied from internet...
    Now what to do ???
    Check for which IDE this code is written from the source you copied code. Or go through the code and convert it for MikroC.
