PELTIER COOLER WITH TEMPERATURE CONTROLLER USING ARDUINO
Dipali Vaniya
@dipali-s4MrEA โ€ข Oct 26, 2024
Project Abstract / Summary : nNormally Air-condition is very costly product and its power consumption is very high. Other air cooler is also cooling product but its not give proper cooling. In between that one another Peltier cooler is very chip product for cooling. So using this Peltier cooler project we will solve this extremely high temperature problem. In this project we will design authentic SMPS Section because Peltier required +12v & 1 to 6 Amp current. This project based on Arduino , Peltier is require proper mechanism for high cooling & heating purpose , so we will use copper & exhaust fan and heat sink. The main application of Peltier cooler is to produce proper mechanism for cooling any area in which it situated.
nIts works like smallest AC cooler in particular area, With control weather according requirement, which can sense the temperature of area. Accordingly temperature it will control the whole system. The principal of Peltier effect is transfer heat from one side of device to the other side. So by using Peltier device we will make a Peltier cooler which is cheaper than other air cooler and power consumption of it is very low then other and cooling of it good then other.
Why did you choose to work on this project topic : By using just a Peltier module operating at 12V DC and 1 to 6 amperes of current, without any moving parts and without using any conventional cooling systems like the vapour compression system or the air conditioning system we have been able to develop lower temperature conditions using our model of the Peltier cooling device.
This project was basically designed as an alternative to conventional cooling method available in the current market, except of the regular cooling methods involving the vapour compression system.
Project Highlights : Because of our project peltier cooler with temperature controller using arduino is Air-condition is very costly product and its power consumption is very high.Other air cooler is also cooling product but its not give proper cooling In between that one another Peltier cooler is very chip product for cooling. So using this Peltier cooler project we can solve this extremely high temperature problem.
Institute/College Name: Hansaba College Of Enginerring End Engineering
City: Siddhpur
State: Gujarat
