PC shutting down abruptly.
Is there any problem with the hardware?
Member • Dec 26, 2009
Member • Dec 27, 2009
Yes, 'userinit.exe' is present in the system32 directory.goyal420check userinit.exe or something like this file in system32
is it there?
Member • Dec 28, 2009
Member • Dec 30, 2009
Thanks for your suggestion, onkssONKSSSSSWell I think Check your heat sink. Even if the RAM (or any other part) is overheated then it might lead to shutdown abruptly. Cleanup Mechanical parts ( Fan ,SMPS, ac adapter etc).
Member • Dec 31, 2009
I'll try your suggestion first.GuttuKeep the cabinet open for sometime. If that stops the problem then you need a better cooling solution.
