Overload protection in vehicles using 8051 micro-controller
~on*kiyu
@onkiyu-I1FNB7 โ€ข Oct 25, 2024
can i get the details about the project topic overload protection in vehicles using 8051 micro-controller , about the circuit diagram, code and the operations?
    @thebigk • Dec 15, 2011
    ~on*kiyucan i get the details about the project topic overload protection in vehicles using 8051 micro-controller , about the circuit diagram, code and the operations?
    ...and someone to explain it to your professors as well?
  • ~on*kiyu
    @onkiyu-I1FNB7 • Dec 15, 2011
    sir its an urgent
    @harshad-ukH5ww • Dec 15, 2011
    If its urgent then i think it's not possible. If you've some time to spent on this project then i can help you with giving idea only. Ready circuit code and pcb is not possible.
  • ~on*kiyu
    sorry sir urgent means it would be fine if u post it within 2 or 3 days.
    i
  • ~on*kiyu
    sir can i get an abstract about the topic?
    ~on*kiyusir can i get an abstract about the topic?
    Why did you choose engineering?
  • ~on*kiyu
    i felt crazy in it when i was small.
    but today it felt a bit difficult in choosing a good project topic with recent technologies involved.
  • RRITESH
    @rritesh-rEBJ6G • Dec 15, 2011
    Hi,
    Does vehicles mean a Robot using gear motor or an IC engine??
  • ~on*kiyu
    an ic engine
  • RRITESH
    an ic engine
    I am not sure how you will couple uC with IC engine better to describe your problem....which loading are you talking about??
  • ~on*kiyu
    sir over load protection means entering more than the allowed persons in a vehicle
  • ~on*kiyu
    can you please describe about the use of a counter in the above topic?
  • RRITESH
    Not sure what to do for controlling the load protecion of engine if it was a motor then there will be rise in current.
  • ~on*kiyu
    sorry sir its not dealing about current . i meant its about locking the vehicle door automatically or to inform the driver about the over load
  • RRITESH
    I think you use some thing like stain gauges sensors at the bottom of chassis(seat especially) connected to base where engine is situated.
  • ~on*kiyu
    can't i design it using microcontroller or in embedded systems?
    You can design easily. You have to make a circuit which measures weight of the persons seating in vehicle and take over the ignition command based on the signal you're getting from weight measurement.
  • ~on*kiyu
    @onkiyu-I1FNB7 • Dec 17, 2011
    by using a counter can't we design it?
  • RRITESH
    @rritesh-rEBJ6G • Dec 17, 2011
    where ??
    @harshad-ukH5ww • Dec 17, 2011
    ~on*kiyuby using a counter can't we design it?
    Any idea, How you are using Counter?
  • ~on*kiyu
    on the door.
    an up counter and a down counter.
  • ~on*kiyu
    and counting the total no of persons entering and leaving
  • RRITESH
    on the door.
    and
    Sound like kidding.
  • RRITESH
    OK, which vechicle are you using?
    is this final year project of yours?
    ~on*kiyuand counting the total no of persons entering and leaving
    What to do when only Two guys with heavy weight enters into car? ๐Ÿ˜จ this is not reliable solution.๐Ÿ˜•
  • ~on*kiyu
    any idea in this way?
  • ~on*kiyu
    no sir i am not considering car.
    it's about buses
  • ~on*kiyu
    RRITESHOK, which vechicle are you using?
    no mini project.
    and main project with this mini project
  • ~on*kiyu
    godfatherWhat to do when only Two guys with heavy weight enters into car? ๐Ÿ˜จ this is not reliable solution.๐Ÿ˜•
    if 2 guys with excess weight enters then how can you enter in to the car.
    most probably there will be not enough space for another person to enter
    ~on*kiyuno sir i am not considering car.
    it's about buses
    in Whatever you are going to install do you think that counting person is proper way. i don't think so. ๐Ÿ˜•
  • ~on*kiyu
    sir are you an indian?
  • ~on*kiyu
    if it is considered in a school bus it will become ok na?
  • RRITESH
    So better to use load cell sensors at bottom the sensor will be connected to uC itself ...
    [โ€‹IMG]
    [โ€‹IMG]
  • ~on*kiyu
    and how it works on the car?
  • RRITESH
  • ~on*kiyu
    how can i make it using micro controller?
  • RRITESH
    I have never use this sensor but searching on Google i found these information better you search.
  • ~on*kiyu
    after reading it i felt that it is not possible to be applied in the vehicle on sveire traffic.
    it can only be applied to 4 wheeler's like car
