  • debu
    @debu-62iszV • Jul 17, 2009
    @Er_Mahendran: Isolation reduces the chances of creating a Ground Loop. <a href="https://en.wikipedia.org/wiki/Ground_loop_%28electricity%29" target="_blank" rel="nofollow noopener noreferrer">Ground Loop %28Electricity%29</a> can explain the problem in more detail then I.
    Hope this helps,
    Regards,
    Debu ๐Ÿ˜€
    Edit: Tektronix also has a beautiful note on this topic #-Link-Snipped-# which is more specific to oscilloscopes.
  • Er_Mahendran
    @er-mahendran-ghvIBl • Jul 17, 2009
    Hello Debu,
    Thanks for your reply. Now I got some idea about ground loop. Can you explain how the oscilloscope ground looping is eliminated by isolating the scope or device under test. Please explain in laymann way.
    Thanks in advance.
  • debu
    @Er_Mahendran: The link I posted from Tektronix explains this in a lot of detail. In Laymen terms;
    The following image shows the problem. The ground for the tested circuit is connected to the testing device at two points. This leads to different ground potentials, and hence the problem as stated before.
    [โ€‹IMG]
    (image taken from #-Link-Snipped-#)
    As is obvious, the simplest remedy for the aforementioned problem is, to disconnect the ground at either of the two places. Now; it is not feasible to disconnect the ground from the test side. The reason being, the supply ground may not always be common. Hence, we choose to isolate the scope.
    Hope this helps,
    Regards,
    Debu ๐Ÿ˜€
  • silenthorde
    @silenthorde-4BLPNZ • Jul 19, 2009
    Even the choice of proper probe is extremely important. Probes introduce resistive, capacitive and inductive loading errors in the system.
    Capacitive loading results in increase in rise time and decrease of BW.
    Inductive loading results in oscillations in the oscilloscope o/p.
    Yale's EE lab website has great resource on oscilloscope probe. heres the link #-Link-Snipped-#
  • Er_Mahendran
    @er-mahendran-ghvIBl • Jul 19, 2009
    Hello Debu,
    Thanks for your reply. It is much useful.
