    @thebigk • Sep 6, 2012
    Avinash Wagholeusing Oracle Vm VirtualBox......want to access PD in XP installed on it...how?
    If you could explain your question a bit in more detail, I might offer some help.
  • theAvinash
    @theavinash-DAs260 • Sep 6, 2012
    I have installed oracle VM VirtualBox on Windows7...and Windows XP as vitual machine on it.. i want to access pendrive while m using XP in VirtualBox...
  • Gandalf
    @gandalf-RPhbu3 • Sep 6, 2012
    if you go to virtual machine settings, you can enable usb from the port settings
    ๐Ÿ˜€ enjoy
    Okay, so PD is Pen Drive! ๐Ÿ˜’. On your virtualbox, check for the USB settings and make sure the options Enable USB Controller and Enable USB 2.0 (EHCI) Controller are ticked. That should make the USB drive accessible. If that doesn't work; the problem could be with the upperfilters key in Windows registry. Here's a video demo of how to fix it -
  • 123_neha
    @123-neha-tdEomC • Sep 6, 2012
    Go to settings
    select usb option
    and add your pendrive there by using the add button
  • theAvinash
    done
    thnx friends ๐Ÿ˜€
