OPPO Launches Oppo N3 And Oppo R5 - Specs, Features And Price At Glance
Sharvari Panchbhai
@sharvari-panchbhai-JOvYc6 • Oct 26, 2024
OPPO Electronics Corp., one of the leading manufacturers in electronics from China, has added not one but two jewels to its glowing crown at a global launch event held in Singapore. The successful event was marked by the launch of two brand new smartphones, Oppo N3 at USD 649 and Oppo R5 at USD 499. Both the smartphones will be available in India soon. The prominent smartphone brand has launched N3 as a latest addition to its N series, which is globally known as the first smartphone to feature an automated swivel camera. The sleek and stylish R5 is just 4.85 mm in width, which makes it the world’s slimmest full high-definition smartphone. Now, let’s have a detailed look at the impressive phones one by one.
OPPO N3
As stated earlier, N series is known for its innovative smartphone cameras and this time N3 is taking this legacy forward by adding an additional function called automation. The 16 megapixel camera has the ability to rotate itself by 206 degrees and also features OPPO’s unique target-tracking focus shift function, which can identify the target in focus and can constantly modify its angle so that it can keep track of the moving target. The camera has dual-mode LED flash and its rotation can be controlled in three ways: O-click, touch access and gestures. These stunning and user-friendly features like free-stop and multi-angle shooting will allow users to take 64 megapixel high resolution pictures with scene modes like Normal, Ultra-HD, Colorful Night, HDR, Panorama, Audio Photo and many more.
N3​
Coming to the technical specifications, N3 is blessed with 2.3GHz Qualcomm Snapdragon 801 Quad-Core (MSM8974AA) processor and Android 4.4 OS with Color OS 2.0. The framework of the handset has the dimensions of 161.2 × 77 × 8.7 mm. The weight of the phone is 192g. Coming with multi-touch, capacitive 5.5-inch screen, Full HD (1920 x 1080 pixels) and 403 PP, the N3’s display is covered by Gorilla Glass 3. N3 is powered by 3000 mAh Li-Po battery with rapid charge feature. It has 2 GB RAM and storage of 32 GB which can be extended up to 128 GB. In addition to the list, N3 also comes with features like 5G Wi-Fi 802.11 b/g/n/a/ac, Bluetooth 4.0, USB OTG and VOOC mini rapid charging system.​
OPPO R5
The ultra-thin smartphone (4.85 mm in width) is not only the first of its kind in terms of thickness but it is also the first smartphone to use phase-change material, which is made of metal, resin and other composite materials. This radical phase-shifting feature helps to improve the thermal efficiency, as heat is generated while using the smartphone. Thus, this ‘Cool Element’ protects its octa-core CPU from heat which in turn increases the life of the phone.
R5​
The 13-megapixel rear camera of R5 comes with Sony Exmor IMX214 BSI sensor and lens of f/2.0 aperture. The latest PI 2.0 Plus Flash Shot technology allows the users to take 50MP high-definition images with a focus time of 0.18 seconds. The 5-megapixel front-facing camera has 83 degree wide angle lens with f/2.0 aperture.
cool Element
​R5 is powered by 1.5GHz Qualcomm Snapdragon 615 Octa-Core (MSM8939) processor and Android 4.4. The 5.2-inch AMOLED screen is surrounded by a beautiful micro-arc frame and offers a resolution of HD (1920 x 1080) pixels with 423 PPI. The weight of R5 is 155 g. Running on 2000 mAh Li-Po battery, R5 has 2 GB RAM and storage of 32 GB. R5 will be available in the market in two colors- silver and gold. OPPO also offers USB-to-3.5mm Audio Adaptor, VOOC mini Rapid Charger and features such as Wi-Fi 802.11 b/g/n/a, Bluetooth 4.0 and USB OTG.
After looking at the specs and features, what are your thoughts about these two new spectacular, breathtaking smartphones? Share with us in the comments section below.
  • Sharvari Panchbhai
    @sharvari-panchbhai-JOvYc6 • Apr 8, 2015
    Oppo N3 with 4G LTE connectivity is now launched in India at Rs. 42,990.
