Oppo Find 7a Priced At Rs. 31,990 In India - Features 4x Faster Charging
Akhilesh Garud
Akhilesh Garud
@akhilesh-garud-OBs9se Oct 27, 2024
Oppo India has launched the Find 7a smartphone, a downgraded version of its earlier device - Find 7 today. This phone runs on Android 4.3 Jelly Bean wrapped under the company’s ColorOS UI. It has a 5.5-inch 1080p display with 403ppi. The display is protected with Corning Gorilla Glass 3. The hardware comprises of a Snapdragon 800 quad-core processor. However the company has lowered its clock speed to 2.3Ghz. On the memory front, the company has reduced the RAM size to 2GB and internal storage space to 16GB, which is thankfully expandable up to 128GB. This phone comes with a 13-megapixel camera on the rear and a 5-megapixel camera on the front. Find 7a is the first phone that features the new VOOC rapid charging technology.
[​IMG]
Having a 2800mAh battery, the charging speed is significantly increased by 400% allowing you to make a call for 2 hours straight after charging for just 5 minutes. With the Rapid Charge, the phone gathers its full energy in the time it takes you to finish your breakfast.
Find 7a is embedded with the world’s first sony IMX214- the second generation of stacked sensor with powerful graphic capabilities that eliminate smear in motion scenes. It features a high pixel transmission rate of upto 480MPs. This phone adopts MaxxAudio effects which are compatible with the voice assistant, 3rd party audio/video players and navigation system.
Other features include connectivity options such as 3G support, NFC, Bluetooth 4.0, Wi-Fi, and GPS/AGPS. This phone will come in black and white color variants and will be available in the market from 12th June at a price of Rs. 31,990.
    Sarathkumar Chandrasekaran
    @sarathkumar-FEGRPw Jun 11, 2014
    oppo definitely smashing with its features and wins my heart with its specs and price!
    good article akhilesh
  • Rajni Jain
    Rajni Jain
    @rajni-E46Rlm Jun 11, 2014
    All the features and specifications given are at a higher side if we compare it from a mid range budget phone (15-25 K). Still, an average person would think twice before spending 30+ K on Oppo device.
    For the once who do not think a lot about their pocket and are crazy about technology, would love to buy the phone and would try out rapid charging technology (5 minutes charging and 2 hours talk time - mind blowing when we think it for a smartphone).
    Wait Wait Wait ! do read about two points about the fast charging that may concerned you a bit?
    • Fast charging can be done only with the VOOC fast charging based charger, which has a very small chord and you may face some problems if your charging switch is at a height or do not have convenience to place the device.
    • Second point is OPPO can be charged with any charger (regular charger will charge it with regular speed). However, Oppo's VOOC charger can not charge any other device.
  • Vikram S Bargah
    Vikram S Bargah
    @vikram-s-EgXevn Jun 11, 2014
    Rajni Jain
    VOOC Fast charger has 7 Pin Connection instead of 5 pin ones, which a normal mini USB charger has. This implies that we can charge it with usual charger. but our usual phone cannot be charged with VOOC charger.
  • Rajni Jain
    Rajni Jain
    Vikram S Bargah
    As I had mentioned earlier, we can charge it with normal charge but it will charge with normal speed as well; it won't be a rapid charging.
    Reason: As you had rightly mentioned that normal charger will not have additional 2 pins which is source of additional current hence with normal charger phone will be charged with normal speed.
  • Akhilesh Garud
    Akhilesh Garud
    @akhilesh-garud-OBs9se Jul 3, 2014
    SarathKumar Chandrasekaran
    thanks. 😀
