opamp
Bharath.lagi
@bharathlagi-u6s9xT โ€ข Oct 22, 2024
I had one TIA board which I got that from my senior, after long days I started using the same, but I'm facing with a problem like when I give an optical power as the input am unable to see the output power.
I tought like opamp might be the culprit and tested the +ve and -ve supply voltages of the opamp which are showing fine.
Is there anyway to test the opamp.??
  • sauravgoswami
    @sauravgoswami-UAfTlI • Jul 10, 2008
    why dont ya make a test bench,which are available in datasheets,or better is replace the op-amp with a new one then see.
