Opamp With One Terminal With AC Input & Other With DC Input.
Abhishek Rawal
@abhishek-fg9tRh โ€ข Oct 23, 2024
As we know, opamp amplifies both ac & dc input signals.
I would like to know what could be the resultant output if one terminal is given dc signal & other with ac signal.
How will differential amp in opamp can differentiate dc-ac signal ?
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Nov 14, 2013
    Differential amplifier sees instantaneous voltage only mate
    It will just compute the difference between the Voltages at that particular instant and doesn't give a damn about the other previous values
    It is a Magnitude difference finder only mate nothing special
  • a.alandkar
    @aalandkar-R9Nf1k Nov 17, 2013
    If you give ac to one terminal and dc to another one, it will compare the voltage levels and then as per its working, o/p will toggle in between +Vsat and -Vsat (in case of dual supply) or in between +Vsat and 0 V (in case of single supply). if the DC is a constant voltage and AC is sine wave then as a result you will get square wave / pulses/ rectangular wave, depending on the applied voltage level. (Simply op-amp will work as a comparator
  • [Prototype]
    @prototype-G9Gn5k Nov 19, 2013
    a.alandkarIf you give ac to one terminal and dc to another one, it will compare the voltage levels and then as per its working, o/p will toggle in between +Vsat and -Vsat (in case of dual supply) or in between +Vsat and 0 V (in case of single supply). if the DC is a constant voltage and AC is sine wave then as a result you will get square wave / pulses/ rectangular wave, depending on the applied voltage level. (Simply op-amp will work as a comparator
    You remind me writing exams in university...๐Ÿ˜๐Ÿ˜›๐Ÿ˜’
  • a.alandkar
    @aalandkar-R9Nf1k Nov 19, 2013
    [Prototype]You remind me writing exams in university...๐Ÿ˜๐Ÿ˜›๐Ÿ˜’
    Generally such questions are asked by the beginners, and they don't understand the gist answers...
  • ABCD ABCD
    @abcd-2NEyMb Nov 19, 2013
    A good question. It just amplifies the sine wave with an offset voltage.
