@elavarasan-4uyrnr • Aug 20, 2009
Hi xian8512
I have not worked in OFDM but iam intrested to know more about it.Can you post some information about this. -
@xian8512-q1j37E • Aug 21, 2009
OFDM is a modulation method and key technology of 4G. And because of its advantages such as the orthogonality of subcarriers and its capability to convert the high-speed Serial data to lower-speed Parallel data,OFDM has better performance in the frequency-selective channel than traditional modulation methods. However, it losses the advantage when there is large frequency offset caused mainly by the asynchronism or the high mobility between the transmitter and receiver. The latter factor is known as the doppler effect which may undermine the orthogonality of subcarriers. So many method are being investigated to avoid such an effect.
@elavarasan-4uyrnr • Aug 22, 2009
thank you for this information
